c1500 5.3 swap
Old Nov 19, 2023 | 05:09 PM
mlimon's Avatar
Default c1500 5.3 swap
i need help with the wiring everything its in place connected but no spark and no injection
Old Nov 19, 2023 | 08:52 PM
More info please.... a LOT more....
Old Nov 20, 2023 | 09:08 AM
rodstored-72's Avatar
agree with post above. but... I recently completed a LS swap of a '13 5.3 into a '86 C10 truck. I utilized the factory ECM, pedal, harness and transmission. the first thing I did was go to "lt1swap" and get the pinout diagram(s) for my year engine. then found the wiring diagrams for both the engine & the vehicle used. I do know that you will need to find at least a "constant on" & key-on" power sources. hope this helps.
good luck
Old Nov 20, 2023 | 03:46 PM
LS1 TJ's Avatar
The basics are.
First double check 12 volts in start and run.
Turn the key to run and you should hear the fuel pump runs for a few seconds and then turn off because the ECM isn't seeing the crank shaft rotate.
If the fuel pump fires up that's good. If it doesn't you need to figure that out. Borrow a fuel pressure gauge (Oreillys) and check fuel pressure at the fuel rail while cranking. Should be 58 PS1.
You must have good grounds. To the engine block. To the frame. Can't have too many good grounds.
Old Nov 20, 2023 | 08:45 PM
mlimon's Avatar
ok so i have a silverado 1991 swap to 5.3 vortec DBW im using a aftermarket wiring harness and its not the original ECM but its program and all that got 12v on the fuses and i don't have any left plugs change the crank and cam sensors already but i dont have spark and fuel injection
Old Nov 20, 2023 | 08:48 PM
mlimon's Avatar
good luck
thanks i will check that
Old Nov 20, 2023 | 08:58 PM
mlimon's Avatar
Originally Posted by LS1 TJ
The basics are.
yes i got pump runing and good pressure good grounds and all that but im still got no injection and no spark
Old Nov 21, 2023 | 09:08 AM
strutaeng's Avatar
Those may or may not be related.
You popped the fuel rails to confirm you are not getting injector spraying? Have you checked the injector wiring to see if you are getting electrical pulsing?
As far as missing spark, that may be related to a crankshaft position sensor (note: if the ECU doesn't have CPS signal it's not going to fire injectors.)
Old Nov 21, 2023 | 09:57 AM
mlimon's Avatar
yes i got fuel on the rails pump its working and i hace good pressure i replaced tha crank sensor its brand new and check the wiring on the injector wiring and i have power
Old Dec 6, 2023 | 09:47 PM
Painters's Avatar
Default C1500
So did you get it going?????
Old Dec 7, 2023 | 05:46 PM
mlimon's Avatar
yes was the wiring harness i got to cutt a few cables y rewire and its running now thanks
Old Dec 12, 2023 | 11:26 AM
gagliano7's Avatar
When i did my swap into my 92 i had the oil pressure sender wired wrong and on the 92 if it doesn't see pressure ( if i remember correctly ) it will stop spark. Once i fixed that i was good.
