SN95 Mustang Rack and Pinion fittings needed?
Old 03-19-2024 | 07:21 PM
Stangman77's Avatar
Default SN95 Mustang Rack and Pinion fittings needed?
I’ve got a sn95 Mustang and I swapped in a lc9 aluminum gen iv ls based engine. Matched a 2010 Camaro ss power steering pump. Issue is I’m using 6an ptfe hose for the pressure side and I’m finding it difficult to locate a reasonably priced pair of fittings for the sn95 Mustang rack and pinion. I see Maximum Motorsports sells the 2 fittings but are $50. For anyone who has gone before me which fittings were you able to source that didn’t leak under pressure. I’ll probably just go with the maximum motorsports fittings but finding it hard to swallow that price. FYI the fittings are male 6an and 14mmx1.5 and the other fitting is 6an and 16mmx1.5. Maximum motorsports part number is st73
thanks
Bill
Old 03-26-2024 | 08:44 AM
Pocket's Avatar
Try BRG-925120
$25 for the pair
Old 03-28-2024 | 06:15 AM
Stangman77's Avatar
Originally Posted by Pocket
Try BRG-925120
$25 for the pair
Thanks for the response Pocket; I dug a bit deeper and there is a shoulder on the maximum motorsport fittings that as the fitting threads in to the rack and pinion the shoulder protrudes into the rack and pinion. Without this shoulder the fitting will bottom out before the o-ring is fully seated so will leak; I bit the bullet and purchased the fittings from maximum motorsports.
Quick Reply: SN95 Mustang Rack and Pinion fittings needed?
