GEN 4 engine in a GEN 3 truck
The following users liked this post:
Tommy42088 (05-27-2024)
Ditch the 6l80 and put the 6.0 with a 4l60 or 80. Much easier swap for you
In Simple Format, No It will not communicate. The Gen 3 truck uses Class 2 communication not can bus. The E38 is can bus. To make it work, you need all the Electronics from the Gen 4 truck.
If you have the engine harness modified to work with an E67 you can make it work.
Facebook Post
The following 3 users liked this post by 1FastBrick:
https://www.facebook.com/watch/?v=429589408292988
Yup guy above elaborated on what I said, didn't think my statement saying all the stuff from the Gen IV truck would be needed was hard to understand.
Bold added to help, again.
E67 is another option and it's been done, just takes more work.
Saw that build a while back that's done well.
Tommy42088 (05-29-2024)
With the E38 it requires you to wire in the E38 BCM, Cluster, and AC control unit because it only supports CAN protocol.
LS BRAVADA (06-09-2024)
![Rotflmao](https://ls1tech.com/forums/images/smilies2/rotflmao.gif)
You have no clue who you're talking about, genius. I mastered the Gen III LS stuff, built enough **** and have enough threads here to back that. You can't even read stuff typed on this forum.
So yea, stay being a "dummy" as you call yourself. Hopefully some woman didn't lower her standards and you two procreated, that's the last thing we need as a society.
Sometimes they get spicy and call you an idiot when they can't figure things out with what they are trying to do..
