V6 to v8 Silverado swap help needed
Got a 2006 Silverado rcsb that originally had a v6 doing a v8 swap got a gen 3 5.3 that came out of a 2001 Tahoe decided to use a a blue green wiring harness and added in the iac controller wiring to keep dbc as the truck originally had it sent the original pcm that came with the motor for tuning to delete vats and change the vin on it as well and now got it all put together and I’m getting a no crank no start went through some diagnosing and was told the pcm could be the issue decided to try to use the original pcm for the truck and the motor cranked kinda confused on what I need to do any help is appreciated
I remember seeing something about not all of the blue green ECU's have the right hardware to drive a DBC throttlebody. There is a missing chip on the ECU board. May need to hunt down the right ECU and flash your existing tune to it.
