Lmk and L83 comparability.
Old Sep 22, 2024 | 05:47 AM
Kingdavid1975's Avatar
Default Lmk and L83 comparability.
What all is interchangeable between a Gen 3, Gen 4, and an L83. I have a low mile L83. I own several Gen 3 and Gen 4 vehicles. I would like to use the short block L83 if possible with Gen 3 or Gen 4 top end. I have aftermarket good flowing heads if I can't use the the L83 heads. I'm just curious if I can get past the reluctor change out will the short block work. Are they physically interchangeable? Say you want to use the L83 crank, rods, and pistons in a Gen 3 block.
Old Sep 22, 2024 | 09:50 AM
Pocket's Avatar
GEN V Crank will fit any LS
It's 58x and has a slip on crank sprocket. Otherwise, the same dims. Same stroke, same bearings etc
It does have an 8 bolt flexplate flange, so use the GEN V flexplate or LSA/LT1 flywheel
LS 2004+ and Gen V rods are identical. Not counting 4.8's
GEN V pistons have unique dish shapes and are mirrored from what LS need in regards to valve clearance. Stick to LS pistons
Old Sep 22, 2024 | 06:13 PM
Ls1Rx-7's Avatar
Man use those l83 heads are amazing and the intake options are much better than the ls stuff. Richard Holdener has a 5.3 sbe l83 with ported heads, cam, intake thats over 560hp NA. Its a cam thats in the 230’s so nothing huge either.
