Smoke test intake
Old Sep 28, 2024 | 12:38 PM
Sixtwoeightyfour's Avatar
Default Smoke test intake
I am just completing my first ls swap. I have a Gen iv 5.3 with fast 92 intake and decided to do a smoke test to make sure that everything sealed up correctly. I put smoke through throttle body into intake.
No pcv valve, small filter on top of valve cover on drivers side and hose from passenger valve cover back into fast intake valley cover doesn’t have vent hose. Smoke starts coming out filter on valve cover, around gasket on oil fill tube on passenger valve cover and through front steam line going to radiator. Would this be normal when doing this test or have I possibly vented this motor incorrectly?
hopefully that all makes sense.
Basically it seems that the crank case is venting smoke when pressured through intake. Sorry for the newbie dumb question. Thanks!
Old Sep 28, 2024 | 03:16 PM
LS1 TJ's Avatar
Seems odd you would get smoke coming out of the steam line. Your smoke test may be indicating you may have a coolant leak like a head gasket?
Old Sep 28, 2024 | 03:21 PM
Full Power's Avatar
Originally Posted by Sixtwoeightyfour
I
. Makes sense ? Not in a GOOD way .
Have you seen this motor run ?
Can you perform a cylinder leak-down test ?
Does cooling system hold pressure ?
Old Sep 28, 2024 | 05:05 PM
I have seen the motor run briefly. I think I’m going to do a leak down on it and see what that turns up. Thanks for the replies
Old Sep 28, 2024 | 07:12 PM
Did leak down test. All cylinders are holding 90-94 psi at 100. Can’t see any leaking in radiator I uncapped vent hose and nothing out of it.
