Dipstick relocation
Old Sep 30, 2024 | 06:36 PM
64galaxie's Avatar
Default Dipstick relocation
Stupid me , I’m putting an LY6 in a 64 Galaxie , so I put a front sump oil pan on it , because all the steering is behind the crossmember , now what do I do about a dipstick, didn’t think that through.
Old Sep 30, 2024 | 08:35 PM
the_merv's Avatar
Veteran: Air Force
LS GTO had a Front Sump Pan and a Dip Stick..
Old Oct 1, 2024 | 11:15 AM
64galaxie's Avatar
Yes , but my block doesn’t have a place for a front dipstick.
Old Oct 1, 2024 | 11:54 AM
Aftermarket or OEM-style pan? OEM should have a provision for a dipstick.
Old Oct 1, 2024 | 05:53 PM
the_merv's Avatar
Veteran: Air Force
The LS Block is what has the Dip Stick in it, all LS Engines. The Pan is flat all around.
Machine Shop can make that happen. ​​​​​​​
Old Oct 2, 2024 | 09:55 AM
Pocket's Avatar
LS don't have front dipsticks
You get the PS side right in front of the starter, that's it
OEM front sump pans like trailblazer either have the spot undrilled or a plug inserted. The pans have dipstick holes cast into them
ICT billet makes aluminum plugs to seal the stock block dipstick hole to use a front sump
Old Oct 2, 2024 | 10:06 AM
64galaxie's Avatar
Yes , I know all these things, but my engine is already built and assembled with a new Wiand front sump pan , I should have clarified that, so I was looking for solutions, I’ll probably just make an aluminum block , drill it and tig weld it in the pan. To accommodate a tube.
Old Oct 3, 2024 | 07:39 AM
Pocket's Avatar
This pan? If so, it has no dipstick provision
https://www.holley.com/products/engi...EUpayixdh8tl-c
You may be able to cut/weld another front sump dipstick bung. I wouldn't cut/weld the block in this case
Old Oct 3, 2024 | 10:08 AM
64galaxie's Avatar
yes , that’s my pan , and I agree, I wouldn’t do anything to the block , I’m going to weld a block in the pan.
Old Nov 25, 2024 | 09:49 PM
lsxponcho's Avatar
Hey, I ran the Moroso pan on my Galaxie, which already had the bung for a universal dipstick on the right bank side of the sump. It would be an easy addition to tig or mig on a threaded bung onto your pan. The universal dipsticks are flexible and mounted easily onto the front tube header bolt or cylinder head accessory hole etc.
would think.
