Ls swap electric fans
i have a radiator with 2 single speed fans that i just installed in my LS swap. The pcm can only control the one hi fan. Can I use the trigger ground from the pcm to activate two relays and turn both fans on? Installing a jumper from one relay pcm trigger wire to the other relay pcm trigger pin? I hope that makes sense. Lol
What you need to be aware of is, that much sudden amp load is hard on the battery and alternator.
I would look into a PWM controller that would ease the fans on only as much as needed
PCM BLUE PIN 42, Fan Low, dark green wire
PCM RED PIN 33, Fan High, dark blue wire
https://ls1tech.com/forums/pcm-diagn...patcher-2.html
Here's a vid I found, might help.
https://www.youtube.com/watch?v=24b4g3AW37M
