98 Camaro 5.3 swap
I'm swapping a 5.3 into my 98 Camaro. It will be running on an Aces Fuel injection system. Will I be able to retain the BCM and all of my accessories on the interior of the car or will I need to rewire it on a stand-alone style set up?
98 Camaros were their first year for the LS1 5.7 engine.
I have no idea, but I wonder if the V6 and V8 cars had very different harnesses and perhaps even BCM. If this was a V6 car, you might just need more V8 car parts.
I had a 1998 V6 Camaro, built only the Engine Wiring Harness, put a Walbro 255 Fuel Pump in it, used a C5 Corvette Regulator, and crammed in a 408ci LS Engine on the LS1 Cradle with a Built T56. Then tuned it to run hard. Everything worked no issues. Used a 2002 Fbody 0411 PCM. I did this back in 2010.
BCM is the same, Gauges are different in the V6 and V8 cars, the Fuse Box has one thing different between the V6 and V8 cars. I moved the one different Fuse and made it to spec for a V8 car.
Stand-alone is not needed when you say you're trying to "save yourself some time". Get the 1998 correct Sensors, wire it right, send it.
If you're set on that particular Aftermarket ECU & wiring for whatever reason you'll be fine with that 1998 car, it's all Analog. You'll just take some time installing it all.
BCM controls the car, that's it. You mentioned it above, nothing about that is Engine or Drivetrain related. Nothing goes to the BCM except maybe the Vehicle Speed signal wire that would go the Speedometer as well, it went to the BCM to give that signal to lock the Doors above a certain speed. That's if that car even did that. Security wire comes out of the VATS Module but not needed with something that's not GM stuff.
other than that the bcm and functions will still work without pcm
I think that we learned that the only connection between the stock PCM and the BCM is Vehicle speed and this is a simple analog signal.
Therefore, any after-market ECU/PCM only need to connect it speedometer output to either the BCM or possibly directly to the speedometer.
Good to know that the BCM is the same, but that doesn't sound like that was even necessary. Sorry if I started this discussion on the wrong foot.
Good luck with your project. Please give us a few updates as you progress.
