ls1 to ls2/3?
Old Mar 5, 2025 | 05:59 PM
KobeGigi's Avatar
Default ls1 to ls2/3?
Been thinking of buying a ls2/3 to replace my ls1 in my 01 TA Auto. Which do you recommend? ls2's are generally cheaper. Is it worth to spend the extra idk few thousand/s on a ls3? Should i buy a complete one or a bare block with pistons and crank and just swap some of the stuff from my ls1. Kinda new to this so i am learning as i read.
Old Mar 5, 2025 | 07:02 PM
the_merv's Avatar
Veteran: Air Force
2005/6 24X LS2 would be my choice, drop right in.
If you want to go LS3 and don't have a problem tearing stuff down to build it, use the LS1 Crank with the LS3 Pistons & Rods and get it all balanced. Then figure out what Heads you want on it.
Old Mar 6, 2025 | 03:01 AM
garadyy's Avatar
2005/6 24X LS2 all day everyday!
