Best way to get reverse lockout?
I want to retain the reverse lockout (because I don't trust myself) and am trying to figure out the best way to set it up. I have cheap reverse lockout and VSS pigtails that I got off Amazon, but can I connect them to the I/O of the Terminator? Will the Terminator X even allow for reverse lockout functionality, or is that something only the Max can do? I know a lot of people recommend the Bowler T56 harness, but I feel like there has to be another solution that doesn't cost $325 (and I'm not running reverse lights, so that would be a waste).
All ideas are appreciate - thanks!
but that being said...you could tie it into a brake switch so you would have to be at a stop holding brakes to get it to activate
I did this to a T56 in a Mustang. Just learn to shift. The shifter always spring loads to the 3, 4 gate. So when shifting 2 to 3. It's straight up with slight pressure to the right.
4 to 5 is the same. Straight up with slight pressure to the right. Avoid the Z move. You will Never upshift through the gears into reverse.
The only time this might be a problem is coasting in neutral and you want 5th. You can clutch in, goto 4rth, then again, straight up with slight pressure to the right. Have no fear, if you put enough spring you should feel if you are entering the reverse gate AND even entering reverse gate is not a problem unless you enter AND push up to engage reverse.
IIRC, when the Dominator sees less than 3mph, it sends outputs to B1 and B3 unlocking the reverse lockout solenoid. Andrew (Dr EFI) did the actual remote tuning.
At this point, I think going the independent module route is going to be the simplest and most cost-effective solution...that or just ripping the whole solenoid out and replacing it with a spring.
That said, I very much like to find a balance between form and function/cost, and I absolutely despise the look of those shifter ***** with the buttons.
I’d much rather remove the solenoid entirely and run a lockout spring over the ball (although I’d still have concerns about missing 5th and going into reverse).
