Best way to get reverse lockout?
Old Apr 18, 2025 | 03:42 PM
HILROD's Avatar
I have a car with pull up ring for reverse. It is mechanically made into the shifter assembly, so it would have to be custom made.
Old Apr 19, 2025 | 01:58 AM
CattleAc's Avatar
Originally Posted by rabinaba
I’d much rather remove the solenoid entirely and run a lockout spring over the ball (although I’d still have concerns about missing 5th and going into reverse).
If your really cheap like me, you can do this...
Reverse Lockout Mod
Old Apr 19, 2025 | 07:55 AM
Pocket's Avatar
Originally Posted by the_merv
Too bad there's no way to make something like the ZF 6spd Transmissions. To get it in Reverse there was a collar with a lip on the Shifter you had to pull up on with two fingers. Early-Mid 90's LT Corvettes. C4 ZR1 had it too.
You can, but there's a good bit that goes into the mod
This guy has an awesome build, but goes into detail on how he adapted a MT82 shifter to a remote mounted TR6060. For a traditional tail mounted T56, the mod is just to the stick/shifter assy. No reason a crafty person couldn't replicate the process
He starts the explanation around 11:00 in this vid
Finishes the mod in the first half of this vid
Basically, buy a shifter with the rev lock feature, weld the shifter stub to the shifter base of the T56. Fabricate a lockout guide. He 3D prints a prototype before CNC milling an aluminum block. Don't see why you couldn't caveman style that with some angle iron and a grinder
A button activating the OE solenoid is still the easiest. Mount it to the ****, stick, console, where ever you want
Old Apr 19, 2025 | 10:41 PM
the_merv's Avatar
Yup, guy doesn't like buttons apparently.
Old Apr 21, 2025 | 12:58 PM
Rt Jam's Avatar
Here is an old vid of the 2 to 3 at 0.12sec. Hard to explain in a written reply but it's straight up with a tiny bit of muscle to the right. No 4 to 5 to demonstrate but you will get the idea. Not sure what gearing you have but a speed shift from 4 to 5 is not necessary in most cars. This had a 3.21 rear gear so top of 4th was around 120mph.
No chance you are going to reverse with this method.
