Walbro Fuel Pump Issue
After 5 years with no issues, my fuel pump started acting up. Then died. I replaced it (New Part# GSS343G3 (Walbro was bought by TI)). The new pump, after 200 miles, quit. The car was on jackstands and the pump would not work (no start, no 5 second prime when key on). I have tested the wiring in the car and it is working perfectly. I pulled the pump and tested the pump while submerged in a bucket of water and it all worked. I applied 12v at the weatherpack connector on the sender, worked. I disconnected the bulkhead connector on the sender assembly and applied 12v there. Worked perfectly. I'm assuming I have a bad connection somewhere, but I cannot find it. One issue that I noticed is that I tested the continuity on the weatherpack connector and all of the prongs had continuity with each other, even the sender wire. It's worked this way for 5 years with no issues, but I didn't expect to find this. I wired this per Racetronix's instructions (When I built the car I upgraded the pump to bulkhead harness and added an redundant ground that goes through a bolt I drilled and mounted through the bulkhead and leads to the car). I'm not sure where to go from here. Everything I bench tested (continuity, 12v positive) and everything worked as it should. I'm not sure what to do next. There must be a bad connection somewhere, but I can't find it.
Here's the weatherpack connector on the topside of the sender assembly. Applying 12v makes the pump work. Also, all 4 prongs (two grounds, power and sender wire) have continuity. I thought the sender wire, at least, would not have continuity to the power wire, but I supposed the way Racretronix had me run extra grounds, it makes sense.
Here is the bulkhead connector. Removing this and applying 12v to the red wire caused the pump to work fine. The screw into the top of the bulkhead is a redundant ground that leads to the car itself.
I tried to get as many angles as I could to show the wiring setup. I tried manipulating the wires to see if I could reproduce a problem but was not able to get it to stop working.
Rick
My question is, what type of plug/pin is this called? I need to get a new one, but don't know what to call it. I also want to replace the connector through the bulkhead.
I double checked and the pin that appears to be broken off/shorter, or maybe even burned off, is the same pin that is for the big red power wire for the pump. Could a power surge or a bad connection have caused this to actually burn the pin?
