LS1 swap not firing correctly help!!
Hello all I have a 2001 Camaro LS1 in my 1951 Cadillac that’s been swaped and I’m having issues with engine vibrations. I replaced the mounts because they were custom made. Had the ecu tuned and gone through. The harmonic balancer was really wobbly so I replaced it seems to fix it a bit. Unfortunately I still have a pretty bad vibration and a slight knock at idle but gets quieter as it warms up. So I pulled spark plug wires off the coils as it was running to check if the engine tone/ram change. So I found that cylinders 2,8,3,5 all didn’t change how the engine ran when I disconnected the plug wire from the coil while running. Does this mean it’s bad coils?injectors,plug wires? Plugs? Plz help any input is appreciated
