SDPC best of both worlds crate engine?
Old Dec 15, 2025 | 08:19 PM
wannafbody's Avatar
Default SDPC best of both worlds crate engine?
https://www.hotrod.com/how-to-and-en...m_type=organic
Old Dec 15, 2025 | 08:20 PM
wannafbody's Avatar
Gen V port injection crate engine.
Old Dec 16, 2025 | 02:24 PM
Project GatTagO's Avatar
The L8Ts are amazing engines.
Andrew
Old Dec 16, 2025 | 04:53 PM
wannafbody's Avatar
Port injection would make it an easier swap into a 3rd or 4th gen than direct injection.
Old Dec 23, 2025 | 04:35 AM
Jimbo1367's Avatar
wouldn’t you be able to use a Holley Terminator X (or Max) then?
thanks
Old Dec 23, 2025 | 10:13 AM
thanks
Holley has Terminator X Max systems for both the port as well as direct injection engines.
Andrew
Old Dec 23, 2025 | 10:54 AM
wannafbody's Avatar
I wasn't aware Terminator X supported direct injection. But port injection simplifies the fuel system, I think.
Old Dec 23, 2025 | 10:59 AM
The Terminator X Max has had support for Gen 5 engines for a long time. Port injection is easier, but you lose the benefits of DI, which are numerous.
Andrew
Old Dec 23, 2025 | 06:30 PM
Jimbo1367's Avatar
My comment pertained to SDPC putting port injection. Since it’s not DI anymore, wouldn’t a 58x Terminator (or Max) work? This is cheaper than the Terminator Max DI.
Some people might already have the regular Terminator X. This woad my whole point.
Old Dec 23, 2025 | 07:32 PM
If someone already had a Gen 4 harness and. A Terminator X Max then you could do port injection on a Gen 5 engine.
Andrew
Old Dec 31, 2025 | 09:05 PM
mrvedit's Avatar
Moderator
The SDPC SDRL8T engine in the Hotrod article is actually port injected; the DI has been removed to make it cheaper and simpler to hot rod the L8T engine. And to swap and run it with an EFI system.
If I were to "LS" swap something now, I would definitely consider the L8T engine. (Technically an "LT" engine). Appears to be the most cost effective new engine with forged crank and rods.
