Transmission going crazy
It's a little quirk that happens on occasion with holley
Lucky my 4l80E controller has an optional touch screen shifting option, so I was able to make it home at reasonable speed by manually shifting from the touch screen.
Swapped in a new sensor and never had an issue again.
BTW, if you get stuck and need to get home in an emergency, you can unplug the 4l80E connector and that should give you second gear.
