Engine Stand ?
Old Aug 18, 2004 | 01:44 PM
55chevy's Avatar
Default Engine Stand ?
This is my first aluminum block engine to work on. Can I use a regular engine stand that bolts to the block on one end to hold the engine? I know it's a dumb question but I don't want to break the aluminum block or heads. Thanks, Steve
Old Aug 18, 2004 | 02:20 PM
67 bird's Avatar
Default Stand
Hey Steve. As long as you get the bolts in at least 1/2 to 3/4 of an inch and tighten it up snug you should be ok. The engine is substantially lighter than the old cast iron blocks of old. J.C.
Old Aug 18, 2004 | 02:28 PM
55chevy's Avatar
Thanks J.C. I knew it was lighter but I was afraid of the aluminum.
Old Aug 18, 2004 | 04:15 PM
NJSPDER's Avatar
teh aluminmum is good and strong. i woudl suggest running a tap down teh botl holes and a die over the bolts first though. aluminum can gaul a lot easier than iron.
later
tim
Old Aug 18, 2004 | 05:19 PM
95 LS1 Camaro's Avatar
later
tim
I would be careful with the tap and die. Whenever you use them they will remove material. Just lubricate the bolts you are going to use and go nice and easy.
I just had my engine on a stand and was thinking the same thing. But there is no worries just dont jump up and down on the front of the block.
Old Aug 19, 2004 | 11:35 AM
55chevy's Avatar
Thanks guys. I may get the engine on the stand this weekend if I don't spend too much time at the Oreally Nationals that's in town.
Old Aug 19, 2004 | 11:58 PM
Keith's Avatar
For soft metals(cast iron, aluminum), the thread engagement should be twice the width of the bolt.
Or at least that's what I learned from reading Marlan Davis.
