fuel system question...
Old Aug 21, 2004 | 09:44 AM
1971ssLS1's Avatar
Default fuel system question...
hey guys, on your conversions how are you guys setting up the fuel system, what pumps to regulators, etc...? aslo what kind of mpg are people getting with these conversions?
Old Aug 21, 2004 | 10:02 AM
Lesrace82's Avatar
bosch 420L pump, -8 feed line, into a speed inc regulator, -6 return off of the regulator back to the tank. -6 feed line to the rails.
Old Aug 21, 2004 | 10:05 AM
1971ssLS1's Avatar
what kind of mpg is anyone with a conversion getting?
Old Aug 21, 2004 | 08:09 PM
70 LS1's Avatar
Conversion master
Walbro 340 255lph inline pump. stock 1999 corvette fuel pressure regulator. Aluminum 3/8" line from the regulator to the engine bay.
25-28 mpg
Old Aug 21, 2004 | 08:53 PM
crainholio's Avatar
Walbro 340 in-tank pump, Aeromotive adjustable fuel pressure regulator mounted in the engine compartment, S&P fuel rail AN-06 adapter, 24mpg highway earlier this summer with lots of loud pedal application.
Old Aug 22, 2004 | 01:24 PM
Payne's Avatar
Im hoping to be over 30 mpg - 2800lb 93 RX7 with a better drag coeficient than a C5.
Since I have to appease the ******* CA smog *****, I will be grafting the camaro intank pump into my RX tank so that the fuel pressure sensor works. (Adjustable FPRs are illegal)
Old Aug 23, 2004 | 02:22 PM
Scooter70's Avatar
25-28 mpg
Same setup here except that I used braided hose to go tank to pump to regulator to hardline in the rear and then braided again from the hardline to the fuel rail in the engine bay.
Dunno what I'm getting for mileage but it's better than the carbed 350 was getting before the LS1 arrived.
Old Aug 23, 2004 | 05:26 PM
Lostpatrolman's Avatar
70LS1, is that 24 mpg highway or city?
Old Aug 23, 2004 | 11:21 PM
70 LS1's Avatar
Conversion master
25-28 is an estimate based on all the driving I do.
Old Aug 24, 2004 | 12:33 AM
Keith's Avatar
For a fuel pump we are using a stock 2000 camaro fuel pump sitting in a 5 gallon bucket.
A brass "tee" connects to high pressure rubber fuel hoses and to the regulator in the stock fuel pump housing.
A swagelok connects the fuel rail to the high pressure hose.
No mpg figures as of yet. We have only had it running in the frame.
Old Aug 25, 2004 | 10:30 PM
LS1Sandrail's Avatar
Carter P4070 boost pump off of tank feediing a one liter external sump (did not want to sump the gas tank) with -6 aluminum hard line. Overflow from sump goes back into the gas tank. 255 LPH Walbro external pump draws from external sump and feeds a Corvette regulator fillter, regulator/filter goes to a stainless Chevy truck EFI filter, then up to the fuel rail. Everything is hardline and AN, except that goofy -5 fuel return off of the Corvette regulator, which is flexable hose.
