Oil Pressure
Old Aug 23, 2004 | 05:00 PM
flyinlowss's Avatar
Default Oil Pressure
For anyone that has aftermarket oil pressure gauges, what is your oil pressure at idle? And what does it go to when its throttled up to about 2500-3000rpm's in park? I think I may have a problem.
Thanks
Old Aug 23, 2004 | 07:12 PM
David(TX)'s Avatar
I have a 2000 LS1 in a 62 Corvette. It idles, hot, in the mid 40's and goes up to the lower 50's from 1200 RPM up.
Good luck.
Old Aug 24, 2004 | 08:14 AM
flyinlowss's Avatar
Thanks, ya I definatly have a problem some where then. With the LS6 ported oil pump it is only putting out about 20lbs at idle. Its not really enough for me.
Old Aug 24, 2004 | 09:08 AM
David(TX)'s Avatar
I had a friend that had LS1 oil pressure problems. The engine did not make noise and ran well, just low oil pressure. The problem was a missing upper half of the #3 main bearing. It was missing from original assembly.
Old Aug 24, 2004 | 12:35 PM
Scooter70's Avatar
I'm not sure whether location of the gauge is relevant or not but I'm running a mechanical gauge (the original 1970 one). It's tapped into the block just above the filter. Cold idle, I have 35psi but hot idle is only about 5psi. It jumps up with any throttle input, so I think my 700rpm idle may be a little low for the ported LS6 oil pump. Can anyone correlate the readings at the filter and the top of the block (the stock location)??
The traditional belief is that you need 10#s of pressure for each 1000 rpm. So if you're idling at 1000, you only need 10psi. I think the big deal is when you're turning 6k and only have 30psi. Then I'd be worried.
Old Aug 24, 2004 | 12:58 PM
PlainwhiteZ28's Avatar
Kenny,
You went through the engine correct?
The only other problem I have ever heard of with PSI is the rubber O ring on the pick up tube. It always seems to get messed up. Check that if your not certain.
Glad you got it running at least
Old Aug 24, 2004 | 02:40 PM
flyinlowss's Avatar
Scooter, I have a guage tapped in the same place as you except mine is electric. Didnt seem to increase the pressure upon accelerating. Ya I am aware on the theory behind the pressure per rpms but I would rather it have more.
PWZ, Yes I went through it and I was a little sceptical of the cam bearings although they had no wear actually showing, they had a lil copper in one small spot like maybe the bearing was kinda tight there. Anyway I have ordered everything I need including a new pump O-ring, cam bearings from Texas Speed earlier today. If it does it again it will get ran until the engine finds the problem itself.
Old Aug 24, 2004 | 03:03 PM
Scooter70's Avatar
If you're not getting more pressure with more revs then there's definitely a problem, regardless of what your idle pressure is. Mine is a little low at idle but it rises (to what I consider acceptable) as soon as the revs rise. I may raise my idle rpm just to see if the hot pressure comes up.
If electric gauges weren't so expensive, I'd consider putting one in the top of the block just to see what the difference is between there and the bottom.
Old Aug 24, 2004 | 03:14 PM
flyinlowss's Avatar
The only way I could see the pressure drop between the two points would be due to flow volume between the top of the block and the bottom. But thats just me. I know on old school there really isnt a significant difference rather you get it from the side at the filter or the top rear of the block.
