motor mounts
Old Sep 18, 2004 | 08:50 PM
livewire0201's Avatar
Default motor mounts
is the distance between motor mounts the same on an ls1 as they are on an early sbc
Old Sep 20, 2004 | 01:05 AM
92CamaroReallySlow's Avatar
Im not sure if the distance between the motor mounts is the same or not, but I know they arnt in the same place. Because you cant just pop an LT1/TPI into an LS1 Kmember/motor mount or viceversa. Im pretty sure the LS1 dimensions are a little different than ealier sbc so Im assuming the distances are differernt by a little.
