Clutch Master Cylinder Info
Old Sep 18, 2004 | 08:51 PM
LS1Diva's Avatar
Default Clutch Master Cylinder Info
For those who need to know. I took a stock master cylinder apart and the bore is 3/4" and the stroke is 1". This info will come in handy for those of you who need to use a Wilwood M/C. Hope this helps somebody.
Old Sep 19, 2004 | 09:27 AM
Budman78's Avatar
Launchin It!
Thanks for the info.
Old Sep 19, 2004 | 02:59 PM
stevieturbo's Avatar
I had enquired about that a while back, but got no answer.
I can also confirm it now too...
Old Sep 20, 2004 | 03:50 AM
Payne's Avatar
A lot of the RX7/LS1 guys are running 7/8 wilwoods, for what its worth.
I just put my motor in today, so I have no idea if it will work for me, but it works for the others...
-Jason
Old Sep 21, 2004 | 04:25 PM
perhaps while they use a larger MC, they may have shorter pedal travel ( or rod travel at the MC )
Old Sep 23, 2004 | 03:39 AM
55LS1's Avatar
great! thanks for the info!! How do you hook up the willwood to the T56? (weird connection)
Old Sep 23, 2004 | 07:42 AM
Project GatTagO's Avatar
Take your stock hose to any good industrial hose supply company. They should be able to cut the end that goes into the stock MC and install an AN fitting.
Andrew
Old Sep 23, 2004 | 11:39 AM
See my post here.
https://ls1tech.com/forums/manual-transmission/215513-t56-slave-cylinder-problem.html
Its quite easy.
