ls1 malibu need advice and help
Old Sep 25, 2004 | 10:36 AM
lt1ls1's Avatar
Default ls1 malibu need advice and help
I wanted to know if any one out there knew how to put a 99 camero ss ls1 in a 79 2 door malibu and if it is possible. I will also have tranny,driveshaft,rearend, and any other parts from the camero except the suspenction. if it can be done what is need and how
Old Sep 26, 2004 | 05:43 PM
John B's Avatar
Moderator
Welome aboard! Malibu & Monte Carlo swap are virtually identical......read on take notes!http://www.montecarloss.com/ls1montecarloss/
Old Sep 26, 2004 | 07:21 PM
lt1ls1's Avatar
Default thanks
this info will be vary helpful. I was also thicking of doing the 4th gen ss swap.
Im getting the engine but can't pick a car. mabe a 67-72 camaro or the malibu i like the idea of the malibu cause it will be sort of a sleeper
you said that the swaps are simmiler do you think i should get the dash and fuel pump also should i get any thing else of the camaro
Old Sep 27, 2004 | 02:00 PM
John B's Avatar
Moderator
No, you won't need them
