Driveshaft Short for LS1 Third Gen!
. I have a 3rd gen conversion k member and I figured that everything would line up right, guess Im wrong. Anyone else have this problem, I only ask because I hadnt heard this problem yet....thanksChris
Also have friends using LS1 driveshafts w/ their gen-1 engines and TH700 trannies, no problems there either.
Sounds like something is wrong w/ your geometry somewhere.
If you can visualize this, the distance between the trans output shaft and the rear diff pinion yoke is greater w/ the rear diff hanging down than it is w/ the rear diff in its loaded position. This will cause the DS yoke to be engaged further rearward than normal on the trans output shaft splines.
. Does anyone have any pics of how far their yokes are in the transmission. The Best V8 Stories One Small Block at Time
Edit: That is for my car, in which the rear end and transmission are both attached to the frame, so they don't move relative to each other. I'm not exactly sure how you'd have to measure for a solid axle car where the rear end goes up and down...
