water pump outlet question...
Old Sep 27, 2004 | 07:26 PM
5.3 racer's Avatar
Default water pump outlet question...
any one had success or no success for that matter moving the upper hose connection on the water pump? is it possible to heat the water pump casting and turn the stainless fitting about 30 degrees ? i'm using an older r4 a/c bracket and tensioner set-up from a coventional sbc and the new tensioner is going to interfere with the upper hose. if i can turn the fitting about 30 degrees it would be great. thanks.
Old Sep 29, 2004 | 09:16 AM
70 LS1's Avatar
Conversion master
The truck version of the water pump has the upper outlet pointing straight up. Maybe this would work for you.
Old Sep 29, 2004 | 08:28 PM
5.3 racer's Avatar
that's the pump i'm using. with the a/c bracket i'm using i need the outlet to point straight forward and up, not pointed to the right slightly. the f-body won't work either, i'm using truck front accessories that put the belt directly in line with the f-body outlet. i talked to guy on ebay that was able to pull the neck out of the pump and press it back in sealing it with loc-tite. that's what i'm going to try unless someone else has some real world experience. thanks.
Old Sep 30, 2004 | 08:51 AM
Scooter70's Avatar
A couple of thoughts.... a) S&P has an adjustable housing that rotates (I think). You might look into it. I think it only goes on the F-body or Corvette water pump. b) I found an OEM housing that came out almost straight. Check this thread out.
Old Sep 30, 2004 | 09:40 PM
Budman78's Avatar
Launchin It!
Anyone look at the Catty water pump, I think it is differnet. I'll look for a pic.
Old Oct 1, 2004 | 05:50 AM
5.3 racer's Avatar
i heated the casting with a torch and turned the outlet with a large pipe. yeah, crude, but it worked. guess i'll know in a couple of weeks if it leaks.
Old Oct 1, 2004 | 09:12 AM
Scooter70's Avatar
Hope it holds.
Old Nov 1, 2004 | 07:29 PM
RX-Ben's Avatar
Up....
Any find out more info on the OEM straight housing? The linked thread references a p/n that isn't correct.
Thanks
Ben
Hope it holds.
Old Nov 1, 2004 | 07:50 PM
Scooter70's Avatar
Ben,
That p/n is the only thing I have to go on. The guy I got it from thought it was from a Trailblazer but Budman looked at his GF's truck and it wasn't the same. Let me try a couple of people that I know to see if the number means anything to them. Maybe they can find out what it's from.
Where in Rochester are you? My wife is from Greece.
-Matt
Old Nov 1, 2004 | 08:48 PM
RX-Ben's Avatar
Thanks very much.
I'm from the city, though my mom taugh middle school in Greece for 25 years.
Ben
Ben,
-Matt
Old Nov 1, 2004 | 10:27 PM
70 LS1's Avatar
Conversion master
Are we talking about the inlet with the thermostat, or the outlet that points out the front?
Old Nov 1, 2004 | 10:29 PM
Budman78's Avatar
Launchin It!
Originally Posted by RX-Ben
Thanks very much.
Ben
Could it be from a V-8 Trailblazer. Also did anyone look at the Catty version yet. I shearched the web and found no pics that would work.
Old Nov 2, 2004 | 07:35 AM
RX-Ben's Avatar
The inlet with the thermostat.
Ben
