Exhaust In First Gen W-ls1
Old Oct 22, 2004 | 01:35 PM
RSSSLS1's Avatar
Default Exhaust In First Gen W-ls1
I hava a 68 camaro, w-2000 LS1, (completly stock) I want to go with a full mandrel bent 3" exhaust w- x-pipe, My question is, with the 3" exhaust will I loose my bottom end torque. Salesman tells me to go with a 2.5".
I have seen some guys use 3" into the mufflers & 2.5" out ( to clear better around the rear axle)
Can anyone tell me what they have used or what the best set up is??
Also what mufflers sound good with the LS1?
Thanks, Jeromie
Old Oct 27, 2004 | 12:12 PM
RSSSLS1's Avatar
Default 1st Gen
if no one knows, what size did everyone here use with their ls1 coversion?????
Old Oct 27, 2004 | 04:32 PM
Worm's Avatar
Surely 3" would be too large unless you're dumping and not going over the axle. Plus 2.5" is all you would need with stock internals by far.
Old Oct 27, 2004 | 04:52 PM
LS69TA's Avatar
I had 3" duals on my 02 Z-28 with a x-pipe and 1 chamber Flowmasters dumped before the axle. I couldn't feel a loss of power. It ran better in my opinion. Best sounding exhaust I've ever heard. I'm gonna do the same on my '69 as well.
Old Oct 28, 2004 | 07:39 AM
Project GatTagO's Avatar
I have a 2.5 inch system in my RX7/LS6. In my opinion 2.5 is big enough and will fit much better than a 3 inch system.
Andrew
Old Oct 28, 2004 | 09:38 AM
Oscar Will's Avatar
I'm using dual 2.5" with a Spintech X pipe and muffler, flows plenty good. The guys at Spintech were also of the opinion that 3" was overkill.
Old Oct 28, 2004 | 10:25 AM
Nine Ball's Avatar
LS1Tech Co-Founder
I have a dual 3" system from Stainless Works on my '69 and it fits just fine over the axle. Definitely the best quality/fitting exhaust system I've ever had in any car.
Not shown are the over-the-axle pipes. Dual 2.5" exhaust would be suitable for 400 rwhp or less, but if you have plans on going higher later on, get the 3" now and be done with it.
Old Oct 28, 2004 | 10:51 AM
RSSSLS1's Avatar
Default muffler type
nineball: what brand of muffler did you go with??? cost on stainless system???
oscar will: what kind of spintech muffler did you go with?? sportman street or xl???
anyone know were to get a good price on dynomax ultraflo's???
Thanks, Jeromie
Old Oct 28, 2004 | 12:08 PM
Worm's Avatar
Nice setup Nineball.
Old Oct 28, 2004 | 12:26 PM
svt's Avatar
svt
Correct me if I'm wrong but 3" tail pipes will not fit between the springs/gas tank and fender. My 2.5" barely fit. Of course '68s don't have tail pipes that extend so it may not be an issue.
-Marc
T56/LS1 -> '69 Camaro
