another ls1 into foxbody question
Old Nov 5, 2004 | 12:28 AM
66 AC COBRA's Avatar
Default another ls1 into foxbody question
well i have been searching and reading for about 5 hours now, got a lot of good stuff but still have some questions
car in question is an 88 mustang coupe, mini tubed, moly cage, etc, this LS1 is only until I can afford to finish the dart based 18* sbc motor
1. big question, can i run stock exhaust manifolds, pass side should clear but i am worried about the driver side, because of the steering shatf, anyone tried it
2. oil pan, i see people saying to get a tubular k member with 4.6gt mounts, I have enough experience fabbing stuff where custom motor and tranny mounts will be easy, along with a cross member if need be
3. why is the 4.6 mounts needed
as it stand i have a POS dnd k member setup for stock ford mounts, the other option would be to use an PA racing k member for chevy mounts, dont want to go with a 4.6 k member unless I have too, because i need to convert to an sbc k member anyway, or I already have the ford 5.0 setup, pics would be awesome, then i could get a good visual for what will and wont work, fabbing a k member is beyond me right now, ill stick with back halfs and roll cages
4. and a wiring question, if i use an s&p harness, will this still shift a 4l60e the proper way, i know it works just fine with a t56, but u dhift that yourself , basically does that harness have the neccesary provisions for the electric auto tranny junk
Old Nov 5, 2004 | 08:17 PM
Lane's Avatar
If you don't use the 4.6 K, you'll either need to 'notch' the oil pan or try the new GTO front sump pan. Don't know for sure, but I believe it(GTO pan) will clear.
Never used the S&P harness, but it should work fine.
Old Nov 6, 2004 | 03:07 AM
im guessing you never got my email oh well
what is different between a 4.6 k memner and a 5.0 k member, i thought that the middle bar would be in the same position on both, to locate the steering rack in the same place as stock, is it so close that a 1/4" would make or break it
i am not afraid of a little notching, i can get it too work
any idea on the stock exhaust manifolds, i cant believe you wouldnt have tried it juat to see, before hacking up some 351w headers
Old Nov 6, 2004 | 01:29 PM
Lane's Avatar
you have mail.
Sorry - been at SEMA all week.
