LT1 and 6 sp into C3 vette
Old Nov 18, 2004 | 03:05 PM
dcshrader's Avatar
Default need help LT1 and 6 sp into C3 vette
Hi I'm planning on installing a 93 LT1 and 6 speed into my 77 vette with a tired L48 and 350 turbo. Will i run into any problems with this swap
Old Nov 19, 2004 | 06:43 AM
badjuju342's Avatar
Deranged Rat Fink
The LT1 is the same motor mount -wise as an older small block chevy so that should be fairly simple . You will probably have to fabricate a rear crossmember for the tranny but that's not that big of a deal. It will be a lot simpler and cheaper than swapping in an LS1 , that's for sure.
Old Nov 19, 2004 | 06:57 AM
Scooter70's Avatar
An LS1 isn't that hard either. The motor mount is done with a simple flat plate and from there everything would be just about the same for the LT1 vs the LS1. Check out my website for pics & info about my swap. We have three LS1 C3s running around this forum with a few more being worked on at this time.
If you don't already have the LT1 and tranny, I'd recommend doing the LS1 instead.
-Matt
