1st gen shifter cable question
Old Dec 13, 2004 | 08:21 AM
68birdls1's Avatar
Default 1st gen shifter cable question
hey guys, at it once again lol. well i am almost ready to drive this beast but i am at yet another stopping point. are yall using any stock stype shifter cables for yalls car or are yall having to custom make one or what? i read somewhere that someone used an impala cable out of an lt1 car?!? or am i crazy lol! but any thing that yall have used that worked please let me know if you dont mind. just ready to drive the f#cker! lol thanks in advance
daniel
Old Dec 13, 2004 | 09:48 AM
01WS6/tamu's Avatar
You can use the shifter, cable and bracket on the trans off of a fourth gen car and it will fit and function perfectly. If you are racing or other wise getting rough, though in my persoanl experience I would suggest a B&M ratchet shifter. I put one in my01 with the stock center console and love it. It would suck to throw that beast into reverse at the track with the stock shifter. But a stock shifter will get you mobile till finds are available.
Old Dec 13, 2004 | 08:14 PM
68birdls1's Avatar
i think i read somewhere that somebody tried to use a stock f-body shifter and that it was toos hort, by like 4 inches! any other advise guys?!?
Old Dec 13, 2004 | 09:15 PM
ahowudoin's Avatar
good ? i need one to
Old Dec 14, 2004 | 02:17 PM
68birdls1's Avatar
nobody that has done the swap can help me out?!?
Old Jan 9, 2005 | 08:06 PM
81LS1Camaro's Avatar
I have been told that a shifter for a 700r4 will work, but I dont know what cable and bracket to use. So I guess I need to know also
Old Jan 9, 2005 | 08:48 PM
68birdls1's Avatar
well it depends on where you set your shifter in place at is what i learned! for me, i had my shifter mounted and then i got a peice of string and tied it off from end to end and i measured and it was 29 inches long which is the same length as a third gen with a 700r4 which is what i bought for my car and which is what worked out great!
Old Jan 12, 2005 | 05:36 PM
ALL UC2's Avatar
I Helped One Of My Friends Do This Swap. He Used The Stock Auto Shifter In The Car And Used The Stock Cable. He Took The Shifter Out And Ground Some New Notches Into The The Plate And Made It Work. On The Cable He Used The Bracket Off The The Powerglide Trans And I Think It Just Bolted On The 4l60e.or He Just Had To Make A New Hole Or Something. I Forget, But I Know That Is What He Used. Also Ricks First Gen. Sells New Decals For Your Plate On The Shifter That Says 1 2 3 D N R P . They Are Like 12 Dollars.
