anyone have dimensions for gto oil pan
Well I thought I had things going my way with the f-body pan, after 3 days of hacking on it and the crossmember of the tacoma, it just isn't going to work. I am going to have to find a gto pan, and I think it will work fine. Does anyone have the dimensions for the gto pan, mainly how far from the front edge of the pan to where the sump ends, and then from the top of the pan to bottom at the thin section. Also I anyone has the part#, or one setting around and would like to get rid of let me know. Thanks.
Here's another tip for you, get the complete GTO setup, you need the pickup, pan baffle and the windage tray and also the oil transfer tubes that bolt onto the side of the pan.
Hope it works out for you this time buddy.
Thanks, I noticed that I would need the extra parts to make it work, hopefully I can find someone that was trying to put a holden/gto swap into about any other car and needed the f-body pan and accesories!!
you can use the stock f-body windage tray
when I bought my pan it came with tubes,baffle,pickup.
and the transfer tubes are inside the pan.
check out my pics.....
https://ls1tech.com/forums/conversions-swaps/250955-ls1-240sx-oil-pan-question.html
1967, 2003, 2004, 2005, bolt, deminsions, dimensions, gto, ls1, measurement, oil, oilpan, pan, size, specifications
