Dreaded Wiring - help and diagrams needed
A list of questions, if you might help out a 21 year old kid trying to do this on his own.
1. Where are you inputting 12V constant?
2. Where do I need 12V switched?
3. Do I need 5V anywhere?
4. Where are you grounding on the block?
5. What does the starter need to see on the small post? 12V when cranking?
6. How do you wire up the clutch depressed kill switch?
7. What did you do to wire up the fuel pump? Im just using a stock LS1 pump
8. What do you wish you knew when you started wiring that you know now?
Sorry for the laundry list of questions, Im having knee surgery the 29th and really want to get her done before then so that I dont have to drive my jetta around for another 3 months
Best,
-Jason
