Close but yet so far......
Old Jan 6, 2005 | 08:52 PM
240sx-ls1's Avatar
Default Close but yet so far......
Is there anyone in the oklahoma area that has completed an LS-1 project? I am in serious need of some advise. I posted about two weeks ago saying that, My 240ss is almost finished the problem is that the motor turns over but will not start. I have just about trouble shot everything. I guess my question is has anyone had this problem with there motor or does anyone know of a shop in the lawton, OKC, or north Texas area? Please help I wanna drive sometime in 2005
Old Jan 6, 2005 | 09:06 PM
Project GatTagO's Avatar
Have you done anything about VATS?
Andrew
Old Jan 6, 2005 | 09:09 PM
240sx-ls1's Avatar
I had the ECU reprogramed to disable the egr and anti-theft. does the vats has anything to do with either? also the 02 sensors.
Old Jan 6, 2005 | 09:21 PM
HotRod68Camaro's Avatar
i had that problem in my 68 the ignition switch was wired incorrect.
Kyle
Old Jan 7, 2005 | 09:29 AM
glennhl's Avatar
Car should start even if there are emissions codes. However, it will not start if the VATS is not disabled.
Old Jan 10, 2005 | 05:06 AM
TheBlurLS1's Avatar
That's what she said...
VATS is the little resistor in the key, that is required to start the motor, unless it's disabled. if the VATS is keeping you from running the car, there should be NO SPARK.
i told you in the other thread, you need fuel, and spark, to run.
go old school man, pull a plug, plug it into the plug wire, hold the threads of the plug itself against the head to ground it, and fire it over to see if you have spark. if you do, then pull an injector out of the intake, and plug it into its respective plug. unplug all the others from the harness and give her a good turning over, check and see if it's squirting.
before you check the injectors, i would unscrew the cap on the end of driverside fuel rail and depress the schrader valve while someone cranks on it. if you get hosed with fuel, you have fuel pressure. do this before ANYTHING ELSE, because its the easiest thing to do.
make sure the engine compartment isnt covered in gasoline when you do the spark plug check or you could have a fire problem.
do this, then come back and tell us the result. if its rolling and rolling over, not even TRYING to start, then you have either a fuel, or a spark problem.
Old Jan 10, 2005 | 06:11 AM
2MuchRiceMakesMeSick's Avatar
Correct me if im wrong but if it was the VATS the motor would not turn over at all. Sounds like a fuel/spark problem
Old Jan 10, 2005 | 08:06 AM
crainholio's Avatar
It depends on how he wired his starter switch.
If he went the simple route like I did, he just took the START output wire from the key switch and connected that to the LS1 harness starter solenoid wire.
No way VATS will prevent this setup from cranking...it just won't actually start.
Old Jan 10, 2005 | 09:23 AM
MrDude_1's Avatar
same thing that TheBlurLS1 said, but a couple tips:
1. have a extra spark plug handy and just connect that one. alot easier then pulling a plug.
2. buy or rent a Noid light from autozone... a noid light is a special light that plugs into the injector connection. every time the injector is pulsed, you should see the light flash instead. simple to check and you dont have to open the fuel system.
3. put a fuel pressure gauge on the system first. much safer then just spraying fuel everywhere, and you can check that the pressure is correct... not just that pressure is there.
Old Jan 10, 2005 | 09:35 AM
MikeM79's Avatar
I had a hard time starting my 2000 LS1 the first time also. Same thing, would turn over but wouldn't start.
I bought my engine then it sat on the floor in my garage for about 2 1/2 years before I installed it. Anyway, it turns out that the injectors were gunked up from sitting so long. I had a friend tap on the injectors while I cranked it and eventually it coughed to life. Initially it ran rough, but it got much better once I put some fuel injector cleaner in the gas (Chevron Techron, iirc).
Your mileage may vary.
Old Jan 23, 2005 | 12:15 PM
240sx-ls1's Avatar
Thanks guy's you really helped with this project, the car started yesterday(I love the sound of a strong V8) It was a wiring problem that I had. But I did try all of you guy's theory's (thankx Blur) The car is up and running now I will be posting pics soon. It is a 96' 240sx with a Silvia frontend conversion.(full carbonfiber) The motor is stock but mod are soon to come. One question: Does this sight has a gallery for us Hybrid guy's if not sounds like a good idea.(hint)
Old Jan 23, 2005 | 10:23 PM
ZULater01's Avatar
Hey 240....I am about to start this project...I would love to get some info from you if possible and see the pics...I can host them also if you want me to. Thanks!
