how many alternator wires?
Old Jan 16, 2005 | 11:23 AM
68birdls1's Avatar
Default how many alternator wires?
i have a speartech wire harness and i was just wondering how many wires are supposed to be going to the alternator. i have one red wire....
the reason i am asking is because the last couple of times i have driven the car, once the car reaches around 200 degrees, its like the battery just lets the car die?!? i just had the alternator checked today and it is great! so if you have any ideas what it could be other than a drain, then please let me have your input. thanks alot
daniel
Old Jan 16, 2005 | 05:17 PM
boondiggys's Avatar
on a stock alt there should be 2 wires coming from the alt. 1 fat red wire that bolts on the rear bottom of the alt. going towards the battery and another skinny one that plugs in the top of alt....what kind of alt are you using?
Old Jan 16, 2005 | 06:07 PM
DaleMX's Avatar
Sounds like something is happening when you go into closed loop. I have not tried the following, but read about it. Maybe do a little reasearch in the tunning section to verify the procedure.
Try unplugging the MAF (force constant open loop operation), start the car and let it get up to 200 and see if the problem goes away. If it keeps running then you may have a bad MAF or o2 sensor.
Old Jan 16, 2005 | 06:25 PM
68birdls1's Avatar
well i dont have a big wire connected to the bottom of my alternator! that might be why i am not charging lol! does that wire go straight to the battery? and i will try your idea tomorrow. thanks alot and please keep the info coming!
daniel
Old Jan 16, 2005 | 06:35 PM
DaleMX's Avatar
Duh!
Yea, to the battery batman! OR the starter.
Glad you found it!
Old Jan 16, 2005 | 07:15 PM
68birdls1's Avatar
awesome, well i will get back to yall tomorrow after i deal with this problem. thanks alot for all the help! i really appreciate yalls quick responses! thanks again
Old Jan 16, 2005 | 08:02 PM
badjuju342's Avatar
Deranged Rat Fink
The wire that plugs in the alt is an "exciter" wire , it comes from the bulb or guage in the dash that is an ignition switched source. It activates the regulator in the alternator and "tells" the alternator when to charge. the color is brown , I believe. If you don't have a battery source larger guage wire on the insulated bolt on terminal in the the back of the alt , it won't charge. Kinda spinning your alternator , so to speak.
Old Jan 16, 2005 | 09:02 PM
68birdls1's Avatar
yea i was startin to freak before yall told me what it was, cause i had the alternator tested and it was great, the battery is brand new duralast gold, and i was just like AHHHH lol!
Old Jan 17, 2005 | 07:39 PM
68birdls1's Avatar
its amazing what happend when you give your alternator a 12 volt source lol... it works. thanks to all who helped, i really appreciate it.
