p0178
Old Jan 17, 2005 | 12:10 AM
boner58's Avatar
Default p0178
I am getting a p0178 code on my truck and it starts real hard in the cold mornings any suggestions? Thank you Daniel
Old Jan 17, 2005 | 09:49 AM
Oscar Will's Avatar
What year truck, what model, what engine.......p0178 is normally a fuel composition circuit code (this circuit senses amount of alcohol in the fuel and fuel temperature) on late model trucks 2002 and newer. The code could mean other problems on older units.
Old Jan 17, 2005 | 09:32 PM
boner58's Avatar
2003 5.3 4x4. Where is the sensor at? What causes the sensor to go bad?
Old Jan 18, 2005 | 07:23 AM
68birdls1's Avatar
http://autorepair.about.com/cs/troub...l_obd_main.htm
Old Jan 19, 2005 | 10:07 AM
boner58's Avatar
I know what the code means now where is that sensor.
Old Jan 19, 2005 | 10:19 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
I don't even show that as a code for an 03 truck. Do you have the L59 engine?
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jan 19, 2005 | 10:31 AM
boner58's Avatar
yeah on the gm tech 2 it is the z engine code
and that is the code it keeps giving me p0178 which makes it very hard to start on cold mornings. I am trying to find out where it is at so that I can replace it
Old Jan 19, 2005 | 10:56 AM
Speartech's Avatar
If forget exactly where it sits, but this is it. It looks expensive!
__________________
www.speartech.com
Old Jan 19, 2005 | 10:58 AM
boner58's Avatar
does it have a part number? thank you
Old Jan 19, 2005 | 11:00 AM
Speartech's Avatar
12563553 is on the casting.
__________________
www.speartech.com
Old Jan 19, 2005 | 11:05 AM
boner58's Avatar
Can you tell who makes it? acdelco? Thank you Daniel
Old Jan 19, 2005 | 11:18 AM
Speartech's Avatar
Siemens.
__________________
www.speartech.com
Old Jan 19, 2005 | 11:33 AM
boner58's Avatar
I am getting p0178 which means Fuel Composition Sensor Circuit Low Input. bad ground? or power problem? or is it just not getting any feed back ie something not hooked up?
Old Jan 19, 2005 | 11:52 AM
Speartech's Avatar
Could be any of 'em. If you have a Tech 2 look for data rather than just codes. You can check the power and ground to the sensor with a DVM. Then look for the signal info with the Tech 2.
__________________
www.speartech.com
