First-gen starting point advantages/disadvantages?
Old Jan 23, 2005 | 11:42 AM
BigBird383's Avatar
Default First-gen starting point advantages/disadvantages?
I am planning on dropping possibly an LT1/t56 combo or LS1/t56 combo into a first-gen Camaro as soon as I find a suitable starting point. Are their any advantages or disadvantages based on the type of engine that was in the car that you start out with? The reason why I ask is because I am looking at a '68 right now with a 454ci and a 4-speed. Will I encounter any more problems (i.e.- motor mounts, etc.) starting with a big block car over a small block car? Thanks
Old Jan 23, 2005 | 01:08 PM
LS69TA's Avatar
The issues should be about the same, but I think you'll have to buy the small block motor stands to mount the engine to. You'll probably have to change the springs out as well in the front b/c of the lighter LT1/LS1.
Old Jan 23, 2005 | 01:11 PM
Nine Ball's Avatar
LS1Tech Co-Founder
No real issues. Either will work as a good starting point. Might be able to sell the big block for a little more coin to put towards the conversion as well.
