Helpful Accessory Drive Conversion GM Part Numbers for OEM Parts
Old 05-02-2008, 04:14 PM
  #41
IOwnCalculus's Avatar
Looks like you'd just need the alternator and its bracket, plus the stock tensioner. My only worry there would be a relative lack of belt wrap around both the crank and the water pump - doesn't the truck setup mount the alternator up top? Maybe that would be a better solution for an alt-only drive.
Old 05-16-2008, 01:56 AM
  #42
mike s.'s Avatar
That is a Camaro accessory drive. Sweet set up, I am assuming thats not your picture if you are asking what parts you would need, do you know who's motor that is, and if that accessory drive works like that?
I don't think the truck alternator mount is the right solution. You might have some interference from the belt in the TB area with the LS6 style intake, even if you removed the idle pulley that does interfere from the bracket and went straight across. A picture will explain better, this is a truck accessory drive with a ls6 style intake laid on top.
I want to adapt the C5 setup, like mentioned way in the beginning of this thread, for my 71 Chevy pickup, without the steering pump. It should work I think, however it would look funny with the alternator stretched out there with a narrow span of width between the belt ends. Has anyone used the setup without the power steering pump? Here is a picture of the C5 setup.
Old 11-03-2008, 12:00 PM
  #43
TRANSAM75's Avatar
Can the LS2/LS7 G.M. #19155067 setup be used on an LS1? I am asking because My dads 65 Nova has nothing right now and we have to decide which GM kit will work better with his TCI front clip.
Old 11-04-2008, 07:51 AM
  #44
TTLS1GP's Avatar
Yes and does that part number include everything listed for the dealer cost $700?
Old 11-21-2008, 09:42 PM
  #45
jmauld's Avatar
Originally Posted by John B
Courtesy of Dave_62 here is a list of parts used for the OEM C5 accessory drive.
Alternator to bracket bolts (2) 24503609
Alt bracket to head bolts (3) 11516357
Alt bracket to head bolt (1) 11516356
P/S fluid reservoir bracket (1) 12555222
P/S fluid reservoir (1) 26046502
P/S reservoir hose (1) 26046910
P/S reservoir cap (1) 26022453
P/S pump (1) 26046503
P/S pump pulley (1) 12559890
P/S pump brace (1) 12555693 Same as f-body
P/S pump bolts (2) 14078896 Same as f-body
P/S pump bolts (2) 11515758 Same as f-body
Belt idler pulley (1) 12564401 Same as f-body
Harmonic balancer (1) 12560115
Belt tensioner assembly (1) 12559325
A/C belt tensioner assembly (1) 12560345 Same as f-body
A/C belt idler pulley (1) 12557334
A/C compressor bracket (1) 12556444
A/C compressor (1) 1137031
A/C bracket stud (1) 12556447
A/C bracket bolt (1) 11515768
A/C compressor bolt (1) 11516714
A/C compressor bolt (1) 12552922
A/C compressor bolt (1) 11509202
A/C compressor nut (1) 10255857
Is there a similar list for the F-body accessories? I'm specifically looking for the p/n's for the bolts. Alternatively, does anyone have a list that shows the sizes so I can just pick up the correct bolts from a fastener or H/W store?
Old 06-30-2009, 12:33 PM
  #46
1936 LS1's Avatar
Default Pics
Thought some pics would add value to this thread (since I've been searching for pics of the different layouts) and save someone a lot of time....
1) F-Body accessories w/o AC (I'm sure someone on here has a good pic of a complete setup).
2) C5 Corvette layout
3) LM7 Truck layout with measurements
4) C5 Corvette verical dimensions
5) C5 Corvette overall dimensions
I haven't yet found a set of dimensions for the F-Body accessory drive layout. If anyone has one or could take some direct measurements and add it here I'm sure it'd be appreciated.
One thing I find odd...The truck layout appears to be the narrowest of the three. Go figure. I realize height is a critical dimension for a lot of swappers but for those of us putting this motor in cars from the 30's, width is our key issue.
HTH someone,
Richard
Attached Thumbnails Helpful Accessory Drive Conversion GM Part Numbers for OEM Parts-f-body-accessory-layout-minus-ac.jpg   Helpful Accessory Drive Conversion GM Part Numbers for OEM Parts-c5-corvette-accessory-layout.jpg   Helpful Accessory Drive Conversion GM Part Numbers for OEM Parts-lm7-truck-motor-accessory-layout.jpg   Helpful Accessory Drive Conversion GM Part Numbers for OEM Parts-corvette-ls1-dimensions2.jpg   Helpful Accessory Drive Conversion GM Part Numbers for OEM Parts-corvettels1dimensions.jpg
Last edited by 1936 LS1; 07-03-2009 at 08:44 AM. Reason: Added C5 pics with dimensions
Old 06-30-2009, 12:39 PM
  #47
1936 LS1's Avatar
Default Link to Car Craft article
Here's a link to a really good LS swap article in Car Craft with a lot of pics and part numbers. Probably a repost, but good info.
http://www.carcraft.com/techarticles...ide/index.html
Old 11-12-2009, 06:40 PM
  #48
gnnova's Avatar
Has anyone comeup with a list of F-body part numbers for the belt setup?
Old 11-16-2009, 05:23 PM
  #49
gnnova's Avatar
Doesn't someone have the camaro setup or maybe know where to look. I tried searching and had no luck.
Old 05-17-2010, 07:49 AM
  #50
leon phelps's Avatar
I was told to use the C6 corvette power steering pulley because it is metal and not plastic. Anyone have a part number for this? Is this info correct? Thanks in advance.
Old 05-17-2010, 06:11 PM
  #51
KENS80V's Avatar
Here is the C6 power steering pulley part number #12568997. Keep in mind that it is 6.70" in diameter.
Old 05-17-2010, 06:39 PM
  #52
what would the difference be with the c5 one?
Thanks as always.
Old 07-04-2010, 10:59 AM
  #53
68Problemchild's Avatar
Anyone care to post torque specs with the parts? I know we all need em.
Old 07-27-2011, 04:42 PM
  #54
V8SC87's Avatar
If you're looking for the exploded parts diagrams with gm part numbers check out compnine.com I've found all of the part numbers for the fbody accessories there.
Old 10-23-2011, 09:55 PM
  #55
LSCustoms's Avatar
that website is down, stating that they are out of business, I am still looking for a complete parts, list, including bolts, as I may have to just order the majority of this from gmpartsdirect.com
Old 10-24-2011, 03:42 PM
  #56
LSCustoms's Avatar
Well I did tons of research and went down to my local dealer and looked up most of it on their computer and had one of their techs help me out a little, this looks to be a pretty complete list, if any changes let me know, as I have posted this in my wtb thread... thought it may help someone esle.
98-2002 Camaro Front Accessories (brackets and pulleys/bolts):
Alternator:
rear bracket PN 12556915
front bracket PN 12563327
alternator bolts (need 2) PN 11516366
alternator bolt (need 1) PN 11516360
alternator PN
Power Steering:
Main Bracket PN 12561584
Front Brace PN 12555693
Pump Bolts (need 2) PN 14078896
Pump Bolts (need 2) PN 11515758
Idler:
Belt Idler Pulley (1) PN 12564401
bolt (if it doesn't come with it and i think it needs a spacer or something?) PN 11516356
Water :
Pump PN 89018053
Pulley PN 12552059
Bolts (apparently you need 6) PN 12551926
Tensioner:
Tensioner (shows that it comes with pulley and bracket) PN 12560344
Bolts (need 2) PN 11515768
Balancer:
Balancer PN 12553118
Washer PN 12600525
Bolt PN 12557840
ARP balancer bolt and washer 234-2503 Summit Racing
Old 10-27-2011, 01:10 PM
  #57
LSCustoms's Avatar
I have more part numbers but I will update this after I get everything I need
Old 05-07-2012, 03:00 PM
  #58
kleyba's Avatar
Default Camaro 2010-11 Accessory Drive LQ4
Hi All;
Did some searching came up with this:
19207665 water pump
12551926 water pump bolt 6x
12587395 water pump inlet
11516480 water pump inlet bolt 2x
89018168 water pump thermostat
12587397 water pump thermostat seal
12628025 water pump tensioner
11515768 water pump tensioner Bolt 2x
12610792 P/S pump bracket
92229662 P/S pump
11588725 P/S pump bolt
12610794 P/S pump pulley
12610789 alternator bracket
13501721 alternator
13502989 alternator
11514597 alternator bracket bolt
11610447 alternator bracket stud
12568996 alternator idler pulley
If I go this route I'd able to keep the balancer of the LQ4 and the AC bracket and compressor.
Questions for this setup:
Still missing some parts just bolts I think? Anything else? Anyone had them?
Does the water pump come with the inlet and thermostat?
There seem to be 2 alternators does anyone know the difference?
2nd option:
The camaro seems to have 2 water pumps:
19180610 this one is also used on the corvette and also has the outlet on driver side but is shorter, this means I'd have to change the balancer.
It seems like I'd have to change all the accesories also but cant find other part numbers for this setup only for the corvette setup with alternator on top.
(I'm looking for alternator on bottom setup)
Is this because this water pump is really just for the corvette? Or do the accessories still work somehow?
Thanks!
Old 05-15-2012, 12:15 PM
  #59
mdrn69velle's Avatar
Does anyone know the new part numbers for these? the don't work on GMPartsdirect.com
Old 05-16-2012, 09:07 AM
  #60
kleyba's Avatar
Hi All;
Thought someone might be interested in this, G8 setup:
19180610 Water pump Corvette Driver Outlet Driver
12551926 Water pump bolt
92236235 A/C Compressor
92252927 A/C Compressor Bracket w/ Tentioner and Pulley
11588734 A/C Compressor Bolt
92067654 A/C Compressor Bracket Stud
11515767 A/C Compressor Bracket Bolt
92234561 A/C Compressor Insulator
92174214 Steering Pump
11588734 Steering Pump Bolt
92218308 Steering Pump Pulley
92067625 Steering Pump Bracket
11518631 Steering Pump Bracket Bolt
92202130 Steering Reservoir
92207627 Steering Reservoir Cap (included with the reservoir)
92068168 Steering Reservoir Bracket
11588738 Steering Reservoir Bracket Bolt
92174420 Steering Reservoir Hose
92193199, 92191127 Generator
11900278 Generator Bolt
92067034 Generator Front Bracket
92067126 Generator Rear Brace
12569301 Tensioner
11515768 Tensioner Bolt
92221552 Idler Pully
The waterpump is the one with the outlet on the driverside.
There is one with the passenger side outlet too.
I'm also missing few bolt for the alternator brackets.
I also did some research on the LSA AC Kit pn 19244106 I think this would fit but I'm not sure does anyone know for sure? This would be much cheaper alternative for the AC since the compressor alone for the G8 is much more then the complete LSA kit.
Cheers!
Quick Reply: Helpful Accessory Drive Conversion GM Part Numbers for OEM Parts
