crate zO6 Motor in 94-95 Camaro or T/A?
Hello, I currently own a 98 SS Vert but am planning on buying a 94-95 Camaro or T/A and I was just wondering how hard would it be and what would the steps be in slapping in a crate zO6 Motor whether it be the 2004 zO6 motor or the new 427 will it all be the same?
Is it possible?
Thanks,
Chris
Is it possible?
Thanks,
Chris
Well not sure about the TA but the Camaro's front end will NOT accomdate the ls6 motor. Clearance issues, also you would have to get the harness and all. I almost did this with my car but after I added it all up way to costly!
Why wouldnt it fit in the camaro? The only thing chevy changed was the front clip/hood. It should fit just fine...the air tract system would need to be configured, but if your going this far that is minute. Motor mounts and harness.... Actually I would buy a 6cylinder car, get a new k member, suspension pieces to harness all that power, a 97 or newer dash so its just a plug and play for the gauges. Then you would have to worry about a tranny crossmember etc, but nothing a little thinking couldnt do...go for it man!!!
