Trailblazer straight 6..
I havn't done anything with it yet, but I think an adapter plate will have to be made in order to bolt it up to most transmissions. (Unless the bellhousing from a trailblazer will bolt up to a regular rwd 4l60)
We've harnessed and set up 3 of them here as test engines.
Good luck with the PCM!
We had to get custom flashed ones from GM engineering to get them running. Maybe that will change if there's enough aftermarket interest in this engine.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
i just think that GM should Make this engine for cars instead of heavy SUV's.. imagine putting one of these in a 3rd gen camaro and then smoking some V8.. and saying you killed him with an N/A straight 6?? ahahha rad
hahaha Ripster
Seems like you could get an FI car up and running, blow up the motor, and the motor is cheap enuff that you can build one on the side.
How about bolting one of those up in a 93-02 4th gen?
That will fit in the same place and mounting as the 4l60-e
if you manage to rig it up please advise me! I can not stand it on my dad's trailblazer-and since I've been mentioning it, it has become a nuissance to him as well
