Old Flywheel on 5.3
Old Feb 27, 2005 | 06:59 PM
BSchroeder's Avatar
Default Old Flywheel on 5.3
Quick question: Will the flywheel off a 77 350 work on a gen III 5.3? I am aware of the difference in backspacing that requires a different pilot bearing. But will the 350 ring gear match up with the 5.3 starter?
Thanks
Old Feb 28, 2005 | 07:41 AM
BSchroeder's Avatar
Back to top
Old Feb 28, 2005 | 08:13 AM
crainholio's Avatar
There's no way it will bolt to the crank, the center hub and bolt pattern aren't compatible.
Old Feb 28, 2005 | 01:07 PM
DuneAddict's Avatar
Default Nop
Ditto!
I just found out the hard way too....
Old Feb 28, 2005 | 06:03 PM
81LS1Camaro's Avatar
How about a later small block one that has a one piece rear main? Has any one tried one of those?
Old Feb 28, 2005 | 08:08 PM
busta9876's Avatar
the later one peice seal flexplate will slid onto the the hub of the 5.3, but the bolt circle is different. they are close, i thought about drilling the holes out but decided to buy a new one correct for my 6.0L.
Old Mar 2, 2005 | 09:06 PM
BSchroeder's Avatar
What about having a machine shop cut the center out and weld in the correct center?
Old Mar 2, 2005 | 10:39 PM
busta9876's Avatar
why not buy the correct flexplate for the correct engine if your willing to go to all that trouble.
Old Mar 3, 2005 | 05:04 AM
crainholio's Avatar
Well shucks, why not just weld the tranny input shaft to the crank so's ya don't even need a flywheel?
(binga binga bing bing binga binga bing)
I guess just buying the right flywheel is out of the question...
Old Mar 3, 2005 | 06:35 AM
BSchroeder's Avatar
It's not out of the question, just more expensive. It also makes sense to me to try to reuse a bunch of parts that are in pristine condition.
Old Mar 3, 2005 | 02:11 PM
crainholio's Avatar
Just put them on eBay and make sure you put "RARE" in the description, you'll get top dollar.
