Which should I go for LS1 or LS6
Old Mar 2, 2005 | 10:49 AM
firefighter's Avatar
Default Which should I go for LS1 or LS6
Well I am starting to learn alot more about shoving a LS something into the Blazer X and I even met a guy today that has the same truck with an LS1 in it. I want to get a crate engine so basically I can get either. The thing is that eventually I will want more power (don't we all?) should I just buy an LS6 so that I already have the better heads and then later just throw a cam and intake with the accompaning valve train. Or should I just save some $$$ upfront buy an LS1 and than later on go off and buy heads and such. Really I guess the question is how good are the LS6 heads vs. aftermarket offerings?
Old Mar 2, 2005 | 11:44 AM
nspr8td lt1's Avatar
if you plan on upgrading, get the ls1. then get a nice heads/cam package from one of the sponsors.
Old Mar 2, 2005 | 02:56 PM
30th TA 0219's Avatar
crate? Get the LQ9 complete with computer etc, or the LS6 complete set-up. The extra 90lbs of teh iron block won't matter much, and you're waaaay ready for FI if you wanted. They are like $3800-4200 complete, depending on where you go, and even have soem accessories. You can always get a LS1 intake for free or next to it, if teh truck is to tall (not to mention low rpm range) or a LS6 intake for $325
Old Mar 2, 2005 | 04:49 PM
Well i'm definatley gonna go with one of the all aluminum mills as it is I'm trying to trim some weight off the damn truck as delivered she weighed 3800lbs w/o my 225lb *** in her. I figure I can get her down to around 3600lbs with some things I got in mind. But what I'm thinking is that I could get the LS6 and then just throw a comp cam, valvetrain and then maybe a FAST intake and a matching TB at it and I shouldn't have to mess with the heads. I mean aren't the LS6 out of the box pretty good? About all I would be looking to get is about another 100hp at the fly that should be more than enough.
Old Mar 2, 2005 | 09:35 PM
****, get a LS1, if your switching intakes and cams and ****. The FAST set-up is over $1000, and you can't really beat a LS6 drivetrain. Get a LS1 and buy AFR heads and FAST stuff, you'll be about the same price and more HP
