Ls1 and Wayne Due subframe
Old Mar 7, 2005 | 03:37 PM
monstertruck's Avatar
Default Ls1 and Wayne Due subframe
I have searched and searched and I cannot get a definite answer. Will the factory Ls1 A/c compressor fit a wayne due corvette style subframe in a 69 camaro. Also, Are there any long or short tube headers that will fit this subframe?
Thanks
Old Mar 7, 2005 | 09:34 PM
ProTouringNyC's Avatar
Default Reply
Thanks
Maybe you can try the guys over at www.Pro-Touring.com you'll find a few guys that have done what your asking good luck
Old Mar 17, 2005 | 02:30 PM
dacajun's Avatar
I have that subframe. However I haven't mounted the engine as of yet. If
I remember right I thing it will, but maybe needs a little tweeking. Have you called Wayne to find out?
Old Mar 17, 2005 | 03:00 PM
ballistic69's Avatar
Thanks
It's not a direct fit. You will need to use the corvette motor mounts and fab up (weld ) mounting plates. If you plan on getting a Wayne Due's front end contact him a see if he will make your subframe specifically for the LS1. I moved my engine back three inches, most 1st gen camaro's you see with an LS1 in them have a big gap between the engine and firewall.
