Interior Wiring Diagram
John
Thanks in advance.
Joe
2002 Pontiac Firebird
Instrument Panel, Gages, and Console Connector End Views
Table 1: Door Lock -- Left
Table 2: Engine Coolant Temperature (ECT) Sensor
Table 3: Fuel Pump and Sender Assembly
Table 4: Instrument Panel Cluster (IPC)
Table 5: Engine Oil Level Switch
Table 6: Engine Oil Pressure (EOP) Sensor
Door Lock -- Left
Connector Part Information
1216-2189
4-Way F Metri-Pack 150.2 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
GRY/BLK
745
Left Front Door Ajar Switch Signal
B-C
Not Used
D
BLK
750
Ground
1216-2194
2-Way F Metri-pack 150 Series Sealed P2S (BLK)
Pin
Wire Color
Circuit No.
Function
A
BRN
718
Low Reference
B
YEL
410
ECT Sensor Signal
1216-0482
4-Way F Metri-pack 150 Series Sealed (BLK)
Pin
Wire Color
Circuit No.
Function
A
PPL
30
Fuel Level Sensor Signal
B
GRY
120
Fuel Pump Supply Voltage
C
BLK
150
Ground
D
BLK/WHT
651
Ground
1206-5803
34-Way F Micro-Pack 100 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A1-A2
Not Used
A3
PNK
39
Ignition 1 Voltage
A4
Not Used
A5
TAN/WHT
33
Brake Warning Indicator Control
A6-A7
Not Used
A8
BRN/WHT
419
MIL Control
A9
Not Used
A10
ORN
640
Battery Positive Voltage
A11
Not Used
A12
LT BLU
14
Left Turn Signal Lamps Supply Voltage
A12
LT BLU/WHT
1414
Left Front Turn Signal Switch Signal
A13
PPL/WHT
237
Instrument Panel Lamp Control
A14-A16
Not Used
A17
LT GRN
11
Headlamp High Beam Supply Voltage
B1
BRN
9
Park Lamp Supply Voltage
B2
Not Used
B3
GRY
728
Security Indicator Control
B4
Not Used
B5
PPL/WHT
1035
Starter Relay Coil Supply Voltage
B6
GRY
1036
IPC Class 2 Serial Data
B7
ORN/BLK
737
Trunk Lamp Control
B8
DK GRN/WHT
817
VSS Signal
B9
GRY
8
Instrument Panel Lamp Supply Voltage - 1
B10
DK BLU
15
Right Turn Signal Lamps Supply Voltage - Europe, Japan
B10
DK BLU/WHT
1415
Right Front Turn Signal Switch Signal - Domestic, Gulf
B11
BLK
650
Ground
B12-B22
Not Used
B14
TAN
31
Oil Pressure Indicator Control
B15
BLK
650
Ground
B16-B17
Not Used
1205-2641
2 Way F Metri-pack 150 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
BLK/WHT
451
Ground
B
BRN
1174
Oil Level Switch Signal
1206-5400
4-Way F Metri-pack 150 Series (GRN)
Pin
Wire Color
Circuit No.
Function
A
TAN
31
B
BLK/WHT
451
Ground (V6 VIN K)
B
Not Used (V8 VIN G)
C-D
Not Used
Document ID# 762845
