ls1 in a Prelude?
Old Mar 26, 2005 | 09:31 AM
ls1_cam2's Avatar
Default ls1 in a Prelude?
The other day my good friend thought up the idea to maybe install a ls1 in his prelude. Well just wanted to get some feed back and ideas about this from the pros........is this crap possible?
Old Mar 26, 2005 | 09:46 AM
02WS6Bird's Avatar
I'm sure its possible, it would be hilarious to see that...I've been noticing alot of the imports becoming candidates for the LS1 conversion.
Trial and Error, do your homework on it size, specs, mounts, all the essentials
Old Mar 26, 2005 | 10:27 AM
ls1_cam2's Avatar
anybody else got any helpful hints, where to start? where can i research? shops maybe? any help is good help
Old Mar 26, 2005 | 10:49 AM
RX7 V8's Avatar
I think It's possible but he will spend lot's of $$$$$$$$ on it. Lots of mod's.
Old Mar 26, 2005 | 11:24 AM
ls1_cam2's Avatar
any idea around what amount or maybe some type of figure?
Old Mar 26, 2005 | 01:28 PM
SurlyJoe's Avatar
It depends who does the work. Put it this way it would be cheaper to buy a nice used f-bod.
Old Mar 26, 2005 | 04:14 PM
Stu Cool's Avatar
Are you thinking of converting the Front Wheel Drive Prelude to Rear Whee Drive? How about starting with a complete Corvette C-5 chassis? I believe wheelbases are similar. In my guestimation you are talking about a $20-50k project depending on how much stuff you already have and how much of the work you can do yourself. Also how much body and paint work is planned.
Pat
Old Mar 29, 2005 | 06:10 PM
john kilgore's Avatar
Default first liar
Pat
there was a guy in detroit that had 2 of the cad corvette type rolling chassics north star motors etc
Old Mar 29, 2005 | 07:41 PM
nspr8td lt1's Avatar
there's a prelude down here (older style) with a mid engine acura v6. so im sure a ls1 would drop right in, it was all custom though.
Old Mar 30, 2005 | 11:09 PM
5.3Silverado04's Avatar
very possible and would surpise the hell out of a lot street racers. There's a 240sx with an LS1 here in Houston. Not sure what all he went through to have it done but I'm sure it wasn't cheap. Sounds like an interesting project..just costly. What gen prelude?
Old Mar 31, 2005 | 04:39 PM
Devoured By Deer's Avatar
ls1_cam2 who is your friend? lol. i have been very seiously considering this swap for my 97 Prelude aka "Lude Behavior". i am a retired riceboy recently entering the world of modern V8s. this engine was an obvious choice as it is relatively compact compared to DOHC engines (it wouldn't surprise me if the thing is shorter in height than my H22A) and there is incredible potential. seeing as i already have the car and it is paid for completely i have estimated costs between 15 and 20 grand for a quality conversion, cost depending on initial engine cost and desired upgrades (which will be minimal because the car is rather light and i dont want to put the engine behind the stock firewall to improve weight transfer and traction). i figure the best way to go would be to have the stock chassis cut enough to allow for the engine and drivetrain and reinforced with round tubing and an integrated cage. a M6 would be preferred as, despite how some might feel, the Prelude is a sports car, and i would like to get my hands on a 80s/90s Corvette IRS but failing that i could settle for all F-body drivetrain components. to be continued...
Old Mar 31, 2005 | 04:42 PM
one of the problems i have run into involving my proposed LS1 Prelude project is the front suspension and steering components. i would like to use struts in front to simplify the conversion but the location of the steering rack (between the engine and firewal is an issue so i may need to resort to a conventional upper and lower control arm setup with the steering rack under the engine. any suggestions would be considered and appreciated. p.s. sorry for the novel.
Old Mar 31, 2005 | 07:43 PM
ls1_cam2's Avatar
really my friend is really my friends its not me. He has a 97 lude that runs ok but i have conviced him that there is nothing like v8 power, so he came with the idea of doing a ls1 into a lude which sounded crazy to me and he asked about how much it would be i told them i dont have a clue. So i did what any reasonable guy would do i asked the pros at ls1tech which rule!!!!might i add. Sounds like(devoured by a deer) would be a good guy to talk to about this will pm you and see if you can get me some pics and ideas on where to start.
Old Mar 31, 2005 | 07:44 PM
ls1_cam2's Avatar
anybody else please looking for all the help i can get from the pros dont want to walk into the pit blind..........
Old Apr 6, 2005 | 07:57 PM
Jonas427's Avatar
It can be done. I have seen 3 RWD preludes. It would make for a hell of a sleeper. I would do it to my Prelude, but I don't have an extra 10k+ sitting around.
OT: Has anyone ever seen an LS1 in an MKIV Supra. I'm sure it would **** off a whole lot of people, but it would be cool.
Old Apr 6, 2005 | 08:06 PM
Gen3Benz's Avatar
It would require extensive fabrication:
front subframe mod or make a new one
make a trans/driveshaft tunnel from sheetmetal
make a rear subframe for a rear axle
and after all that time and money it would still be a honda prelude.
much, much easier to start with a RWD car:
rx7,300z/280z,miata,s2000,944
