2nd gen T/A
Old Mar 28, 2005 | 07:59 PM
Gutz's Avatar
Default 2nd gen T/A
Hey everybody !I am new to this site and it looks awesome!I have an 81 T/a that I am in the works of swapping interiors with an 00-02 T/A.Still buying parts of ebay.I have a question for you guys.I have beeen doing some research on swapping an lsi into my car.I have looked in the forum here and followed all the links.Looks like a lot of work but it will be worth it.Is there anybody that sells an install kit for this engine(motor mounts ,sub frame,computer) to fit in my 81 T/A?I was looking in ebay awile ago and seen a wrecker that said they sold subframes and wiring harnesses for this swap,but of course i didn't write the seller down. Any info anybody can give me would be great.Thanks alot for all your time.
Old Mar 28, 2005 | 09:05 PM
Lesrace82's Avatar
I made motor mount adapters, looks like the ones from S&P. Trans crossmember is easy to make as well, then you just need to get exhaust and fuel system taken care of. Speartech can do your harness to make it run. Its not that hard, just something you have to decide you want to do or not.
Old Apr 2, 2005 | 11:11 AM
Rottluver's Avatar
I am DYING to get myself another '79-'81 TA and drop an LS2 into her & use the '80-'81 Turbo TA hood instead of the shaker hood. I had a '79 WS6 with the Olds 403 big block back when I was a kid......I miss my girl.
Old Apr 19, 2005 | 09:50 AM
Lt14mla's Avatar
im very intersted in dropping an ls1 into a 2nd gen TA as well maybe a 78 or 79. If someone could provide any information about this or where i can find some info that would be much obliged.
Old Apr 19, 2005 | 04:20 PM
81LS1Camaro's Avatar
This is all I did also, the actual hard part is getting all of the little stuff done. It only took me a couple of days to get the frame notched for my a/c and to get the engine bolted in.
Old Apr 19, 2005 | 04:26 PM
https://ls1tech.com/forums/showthrea...hlight=2nd+gen
http://www.tynic.com/81ls1ta/81ls1ta.htm
https://ls1tech.com/forums/conversions-swaps/131175-ls1-2nd-gen-camaro-help-needed.html
If you want more info, just search the conversions forum for 2nd gen and there should be all the info you would ever need.
