Gauge ???????s
Old Mar 31, 2005 | 05:50 PM
72ChevelleConv.LS1's Avatar
Default Gauge ???????s
Hi, I am getting ready to buy gauges. I am wondering if I can modify a set of GM gauges to work for my project. LS1 and 4L60E my harness has one lead for the Tack and one for the Speedo. will any gm gage cluster work? I can buy a Decoda set up but I am not interested in digital. if I buy an electric speedo, will the odometer work too? Thanks for any help.
Old Mar 31, 2005 | 09:14 PM
TJ's Avatar
TJ
you can make the gauges work, but you will more than likely need a couple of dakota digital SGI boxes to convert the signals.
ls1 tach reads as if it were a 4cly, and the speedo has a different PPM than a standard chevy signal.
Old Apr 1, 2005 | 05:13 AM
What is a ppm? if I try like a newer say truck gauges, and use the tack and speedo, most of the trucks have at least a 4L60 or 4L80E would I need converter boxes? Will I need a 4 cyl tack, or do most GM ones work the same?
Old Apr 1, 2005 | 12:05 PM
ls1_chevelle's Avatar
I'm using Defi gauges for my 72 Chevelle with a 03 6.0l in it. Yet to hook them up but they'll just be run off from the sensors. Only gauge I splice into the harness is with my speedo cable. I have no odometer though...
-Matt
Old Apr 1, 2005 | 01:15 PM
[QUOTE=ls1_chevelle]I'm using Defi gauges for my 72 Chevelle with a 03 6.0l in it. Yet to hook them up but they'll just be run off from the sensors. Only gauge I splice into the harness is with my speedo cable. I have no odometer though...
-Matt
What car did you get the gauges out of? will you modify the chevelle dash? Thanks,
Old Apr 1, 2005 | 07:31 PM
The gauges are like Autometer but a different company. I will be removing the sweeper part of the dash and making a plate for the gauges. Putting a cluster from a GM vehicle doesn't look proper in the Chevelle. I'll dig up a pic.
Its not the best pic, but you get the idea.
-Matt
Old Apr 3, 2005 | 11:04 AM
Thanks matt I saw that too. I was thinking of using the new gauges and cutting them to fit the same size hole as the stock ones so when looking through the ss holes they would look more stock. I will keep seeing if they can be hooked up. Any help from all will help.
Old Apr 3, 2005 | 05:57 PM
81LS1Camaro's Avatar
I just got Dakota Digital gauges custom built for my car, I like the idea of it doing 0-60, 1/4 mile, and top speed recall, but like you said you dont want digital. I will have to let you guys know how they look when I finally get them back, they said it would be 2-3 months.
Old Apr 4, 2005 | 05:23 AM
Cool, If I don't find out some info soon, I will need to go Dacoda too. Let me know if you like them.
Old Apr 4, 2005 | 04:16 PM
I was also wondering if I could just use the stock senders to hook up to some cheapo gauges to get my car running while I wait for my good gauges. I dont want to wait
Old Apr 4, 2005 | 06:01 PM
Heres a pic to chew on. Major bitch to get it all to fit right though(from what the owner told me)
-Matt
Oscar Will's Avatar
I'm using VDO gauges, the electronic speedo is fully programmable and the lead from the PCM just plugs in....you do a calibration run and that's it. It is even set up so you can "fine tune" it for more accurracy. The rest of the gauges required the VDO senders
Old Apr 4, 2005 | 09:40 PM
Thanks guys, the above shot is what I am looking to do. it looks great Thanks I will keep looking and see what I can come up with Ill look at the VDO too.
Old Apr 4, 2005 | 11:04 PM
rat496boy's Avatar
i might be late to this convo but here is what i did with my chevelle dash. i didn't like anything out there so we created our own.
Old Apr 5, 2005 | 05:08 AM
I like that, what dash did you use? the sweep one? Did you need any Black boxes? The Auto meter tech guy I talked to yesterday said, the tack they sell will work set as a 4 cyl and the speedo should work from the VSS wire. That looks to be 5" ans 2.5" gauges. Did you have any clerence probs in the back? Thanks for the post.
Old Apr 5, 2005 | 12:55 PM
rat496boy's Avatar
thats a monte carlo/SS dash but it will work in both just more cutting. its a insert that we made to go on top of the stock piece and screw to it. if i pull that off its the stock dash underneith, but cut up for the gauges. i have a 454 so i don't have a LS1, but i can figure out the gauges if i think about it. those are 5in speedo and tach and 2 5/8th everything else. there was no clearence problems behind there. i can reach up from the back and service everything still with it like that. its huge in there. i can copy that insert if you want, but it won't be cheap, over 33 hours in just that....
Old Apr 5, 2005 | 09:40 PM
It looks sweet! I will look at what I have now and see if this is the way I will do it. thanks for the reply I will let you know.
Old Apr 5, 2005 | 11:24 PM
rat496boy's Avatar
i can also make it so you can use all the stock stuff for the heat and air also. i just put a TV in mine becouse it seemed like the right thing to do.
Old Apr 6, 2005 | 08:16 PM
Thanks....
Old Apr 7, 2005 | 09:42 AM
ETS's Avatar
ETS
Have you seen the chevelle setups at www.covansclassic.com ? This is the setup Iam going to use in my 72' Chevelle. It's a little pricey but I think it's a good value if don't have time to fabricate your own.
