PCM Connector Pins
Old Mar 31, 2005 | 08:06 PM
LS1Diva's Avatar
Default PCM Connector Pins
How do you remove the pins from the blue & red PCM connectors
Old Apr 1, 2005 | 10:52 AM
2004tr's Avatar
Yes likewise HELP needed
I hope someone will respond with what is probably an easy answer before I mess up.
My harness got modified but pretty certain RED10 was taken out in error so no Engine speed (Tacho)
I need to put it back in place wihtout loosing all wires
Thanks
Old Apr 1, 2005 | 11:01 AM
slow's Avatar
you simply remove the holder around the pins, and you can then slide in or remove individual pins no problem.
Ryan
Old Apr 1, 2005 | 11:15 AM
2004tr's Avatar
Thanks Ryan
I guess that is unclipping the whole white plastic holder - I was hoping that half could be unclipped at a time.
Do the wires stay in place rather than easily slide out - my concern is that they all come out at once.
Old Apr 1, 2005 | 12:33 PM
88SS LS1's Avatar
I didn't have access to the Kent Moore tools for removing the pins so I used a precision screwdriver and a paperclip to remove the pins/wires that I did not need.
Old Apr 1, 2005 | 12:45 PM
Oscar Will's Avatar
The other connectors will stay put
Old Apr 1, 2005 | 12:51 PM
2004tr's Avatar
Thanks all - my weekend now sorted
Trevor
Replica Cobra - LS1 T56
Old Apr 1, 2005 | 01:12 PM
72ChevelleConv.LS1's Avatar
The plugs need to be removed from the computer then remove the red or blue plastic parts. then from the front (pin side) you will see white fingers, use a thin screwdriver and tip them back while pulling on each wire. they come out like butter. Hope this helps a little more.
Old Apr 1, 2005 | 05:28 PM
LS1Diva's Avatar
Thanks for the replies!!!
Old Apr 2, 2005 | 02:36 AM
2004tr's Avatar
72 ChevelleConvLS1
Great description - 5 minute job from your advice
Thanks Trevor
