LS1 3rd gens
up on stands
LS1 and T56 ready to go in
no motor
Thanks for any help!
-Jeremy
MrDude_1 collected a good bit of info on wiring that may or may not be useable for your car. I think his is a '91.
There's so much variation in connector pinouts from year to year on thirdgens that I don't even bother posting mine...my '82 C100 and C207 pinouts undewent at least 8 changes just to get an '88 TPI harness to connect and function back when I did that swap. If someone's swapping an '01 LS1 into an '82 Camaro they're in luck, otherwise it's worthless.
How much? Did you ship your 3rd gen and 4th gen harness to them or what?
https://ls1tech.com/forums/conversions-swaps/297938-plug-play-harness.html
https://ls1tech.com/forums/showthread.php?t=297938
on a related note....
have you noticed how much the search feature SUCKS on this website?
i donno what the deal is... perhaps its rating threads, or it doesnt update the search database often, or whatever.... in anycase, i can make a post, then the next day, search on words or even phrases i KNOW i posted, and search under my name, and it doesnt come up.
the search feature is either buggy, or it uses some thread rating system or somthing... because its really hit and miss.
*Thanks for the link to that other post though!
John charged me $750 for reworking the harness, and there are about 8 wires or so that will need to be tied in to the dash in order for the stock gauges to work. (Speedo and Tach need signal converter adapters, as well).
I went the $750 rework option because I needed to keep all the emissions equipment intact. Otherwise I could have gone the $450 option and had them make a custom harness from scratch, and just sold the stock LS1 harness.
I also paid him $50 to reflash my PCM from an A4 to an M6.
You want to use the Advanced Search feature, not the little popup box. This lets you pick specific forums and narrow the date range.
Any chance you could get me his contact info? I'd like to talk with him about his headers.
Thanks!
the mustang shorties sweep back without droping much from the exhaust ports, not sure but they might fit in a 3rd gen.
as for the harness, i just got done putting a LT1 in a 88 Firebird (originally 305 thorttole bodie) was able to get all guages working and speedo with stock lt1 harness...only used a few wires from the factory harness.
I found the power wires in the harness, removing the fueses, and using a ohm meter to find which wires went to which fueses, the LT1 computer coil, injectors uses the fueses on the fues panel as they are labled...nice install.
gm is nice that colors are for the most part very common among gm vehicles.
pinks are key hot, oranges are hot at all times, green is usually temp signal, etc etc...
good luck, im in souther missouri, your in St louis..pm me with any qustions ive done a few swaps
*As for those 4th gen FLP headers up above.... they will NOT work.
*Believe me, I test fitted them on my engine stand with a stock k-member bolted to the engine.... it just won't work. This is why I just ordered my Stainless Works LS1 full length headers from www.hawksthirdgenparts.com today
