Starter problem
Old Apr 10, 2005 | 05:17 PM
Sublime69's Avatar
Default Starter problem
I just put an LS1 in a 65 Chevelle and i cant the starter to turn over.
I have all the wiring hooked up and the computer.
The stock starter for the 65 has 3 wires: 1) big wire from the battery and 2 little wires to go to 2 little posts.
Now for the ls1 starter i put the big wire from the battery on the big post and there is only one little post, so i tried both of the little wires and i get nothing???
Is there something im forgetting???
Thanks
Old Apr 10, 2005 | 09:41 PM
troyboy468's Avatar
should be a purple wire (dont need the yellow wire at all). make sure the small juction box up on core support or inner fender is hooked to battery or you wont get power into the car.
Old Apr 11, 2005 | 08:27 AM
Dirtpoor's Avatar
You should have a purple wire that goes to the starter it comes from the ignition switch and also goes through the neutral safety switch this wire should have power on it when the ignition switch is in the crank position if not you may want to check for power to your ignition switch if thats ok ckeck your neutral safety switch.
Old Apr 11, 2005 | 09:11 AM
LS69TA's Avatar
I had the same problem this weekend. Then I bypassed the neutral safety switch, and it spun over.
Old Apr 11, 2005 | 10:21 AM
MrDude_1's Avatar
i also had the same problem this weekend... bypassed the neutral saftey switch, grounded the relay, ect....
turned out, the relay wasnt firmly seated into the plug... wasted 30mins of my day..
Old Apr 11, 2005 | 01:12 PM
Sublime69's Avatar
thanks guys, ill check the neutral saftey switch and let ya know what happens
