Twin turbo LS6 in a sandrail
Old Apr 17, 2005 | 04:34 PM
Captwho's Avatar
Default Twin turbo LS6 in a sandrail
I'm building a high horsepower twin turbo LS6 in a sandrail and would like some advice on which computer you think I should run and why. I might be running over 15 psi. Pros and cons?
Old Apr 17, 2005 | 05:28 PM
sandking's Avatar
Most of the sandrail builders are using Haltech, Holley Commander, Delphi, Motec. You can call Turnkey 760-941-2741 or Redline Performance 714-777-5758
Old Apr 18, 2005 | 02:46 PM
Remington H.'s Avatar
That would be pretty sweet but you will definitely have a hard time keeping the front wheels on the ground unless its a tube framed school bus for like 10 or more passengers. I would suggest a fast system or a rewired stand alone gm harness/computer. If your going ***** to the walls for cam and as wild as you can go and maybe more-so in the future, I would suggest the fast system.
Remington
Old Apr 18, 2005 | 10:27 PM
IMD's Avatar
IMD
cons-will probably wheelie over backwards
pros-will probably wheelie over backwards.
Old Apr 21, 2005 | 01:49 PM
Captwho's Avatar
I am going to try and tune this thing for 750 rwhp. I heard efilive just came out with a 2 bar program for the factory computer. I think I am going to try that since nothing else is better. Does anyone know the horsepower limits of the block itself (that's the only factory piece left in the motor)? any other motor input is certainly welcomed.
Old Apr 21, 2005 | 02:31 PM
MrDude_1's Avatar
the first weak link in the block design is the 4 bolts per cyl... so ARP studs go a good ways fixing that..
as far as i know, no-one has cracked a stock block in half yet......
Old Apr 22, 2005 | 09:27 AM
Oscar Will's Avatar
I have seen only one cracked block. It was a 1998 F body motor that #2 main bearing "spun". It tore up the crank, fried the bearing and caused a 4 inch long crack in the main web straight up toward the camshaft. It was a very heavy dose of NOS that contributed to the failure.
