LS1 Swap FAQs
Old Nov 17, 2011 | 01:30 PM
  #181
RenoReno2's Avatar
Very good thread.. Thanks for the write up
Old Nov 25, 2011 | 09:44 PM
  #182
chevymec's Avatar
Subscribing !!
Old Jan 15, 2012 | 02:35 AM
  #183
veltboy618's Avatar
Do you have diagrams for a 2002 GMC Sierra
Old Jan 16, 2012 | 04:18 PM
  #184
chevymec's Avatar
Subscribing.
Old Jan 16, 2012 | 05:02 PM
  #185
LS1MCSS's Avatar
Originally Posted by Pzary3233
I too am interested in the wiring for an '01 6.0 LQ4... the search button doesn't work for that one....
Here ya go.
Old Feb 6, 2012 | 05:50 AM
  #186
1096s's Avatar
Anyone got the engine/trans wiring diagrams for a 2009 Silverado 2500 hd ly6/6l90e ? I'm fitting one to my Holden one tonner.
cheers,
Barra.
Old Mar 6, 2012 | 08:18 AM
  #187
12SEC SS's Avatar
Originally Posted by 1096s
anyone got the engine/trans wiring diagrams for a 2009 silverado 2500 hd ly6/6l90e ? I'm fitting one to my holden one tonner.
Cheers,
barra.
2009 Silverado 2500HD Vin K 1of5.pdf
2009 Silverado 2500HD Vin K 2of5.pdf
2009 Silverado 2500HD Vin K 3of5.pdf
2009 Silverado 2500HD Vin K 4of5.pdf
2009 Silverado 2500HD Vin K 5of5.pdf
Old Apr 7, 2012 | 11:51 AM
  #188
classicdoug's Avatar
Can anyone tell me it the wiring is the same for a 2008 ls7 and a 2010 ls7?
I have a computer from a 2008 that has been flashed to run without VATS and anything else not necessary. The harness came with the engine I bought (supposedly a 2010, but not sure) and I had it converted to a stand alone harness to install in a 56 Chevy Belair.
The problem I'm having is that the o2 sensors are not reading. When hooked to a laptop, they both stay right around 445.
Everything else looks like it's working on the laptop.
Old May 7, 2012 | 07:50 PM
  #189
tta656's Avatar
subscribing...
Old May 17, 2012 | 08:32 PM
  #190
oldschoolmuscle's Avatar
subscribing
Old Jul 29, 2012 | 04:39 PM
  #191
AlterEgo's Avatar
Default 2005 tahoe
subscribing also!
I see a few harness schematics for silverados, I was wondering if one of them are the same as a 2005 Tahoe???
If its not, can someone post it for that please? I got a 4.8L out of one that I am using for my swap...
Old Jul 29, 2012 | 04:40 PM
  #192
AlterEgo's Avatar
oh yea, Im swapping into a 70 chevelle if it matters...
Old Jul 29, 2012 | 05:26 PM
  #193
Pzary3233's Avatar
www.lt1swap.com check out their wiring section it is good for all gen 3 and 4 truck schematics and pin outs. Dive in it is easy!!!
Old Oct 6, 2012 | 04:14 PM
  #194
bakomack's Avatar
1988 lsxfox
5.3/4l60e combo
I need to know if the stop lamp feed wire needs to have 12v when brake is pressed or is it like tcc wire that is12v constant and needs to get 0v when brake is pressed?
Old Dec 1, 2012 | 11:08 AM
  #195
E40_Guy's Avatar
wow, awesome!!!
Old Feb 10, 2013 | 08:43 PM
  #196
bilden010's Avatar
Do you have pinouts for 2001 8.1 Vortec Mag HO
Old Dec 14, 2013 | 10:52 PM
  #197
1-87 chevy's Avatar
does anyone have the harness pinouts for a 2011 chevy Silverado 5.3 6l80e ?
Old Jun 30, 2014 | 07:50 PM
  #198
fxrider71's Avatar
Default 2004 Rainier 5.3
Is the pinout the same for a Rainier / trailblazer the same as 2004 truck?
Old Jul 8, 2014 | 09:13 PM
  #199
78LS1bu's Avatar
Default Finally getting it done....
....but! Lots of questions. It's gonna be a bit long. Sorry!
I started my conversion on a 78 Malibu with a 97 or 98 F-Body LS1-T56 combo. Purchased the motor/trans/harness back in 2003 from a guy that was in the swap meet area at the Indy Super Chevy Show. He's located in New Albany IN so I drove down there to get everything I could. Body computer, cruise control, ABS sensors and harness, steering column, fuel tank with sending unit, I don't remember what else. He said "get what you want off the car, it's the same price".
Anywho, I started following John's method back in '04 but everything got put aside in '05. After a decade I'm finally getting it together. The F body oil pan has been trimmed, I have a 4.3 Monte fuel tank, the clutch pedal is in the mail from GSI, and I took the opportunity to ride up to Speartech to drop off the PCM.
I understand what needs to be done to modify my harness for stand-alone operation, and re-familiarizing myself with VSS issues as well as A/C, cruise control and whatnot.
Here's my questions (finally ), My fuel rail is returnless, I'm going with the Corvette filter/regulator. Was the pressure regulated on the F-Body in the tank? If so, does the PCM need to be modified to accommodate the Corvette regulator? Will the Corvette regulator work once I get it running and start going into the motor? Does performance suffer dependent upon proximity to the tank or engine? What type connectors are in the harness and what tool is everyone using to pull the pins from the connectors?
Old Feb 1, 2015 | 08:36 PM
  #200
jayvar's Avatar
Default I think I messed up.
Ok so I was wiring up the fuse block and relays and I hooked up the Orange wires and noticed that the other side was not hooked up to anything and the diagram said it returns switch power to the pcm so I want to know where these hooks up.
