Power Steering Delete
Old Apr 26, 2005 | 12:40 PM
redmist's Avatar
Default Power Steering Delete
Hi I have a LS1 in a very light weight BMW and would like to eliminate the power steering and tensioner nearby. What size belt would I need to accomplish this. All the pulleys are OEM (1998).
Thanks for your help.
Old Apr 26, 2005 | 12:42 PM
MrDude_1's Avatar
if you lookup "short belt mod" on the other parts of this forum, you'll find the answer and everything thats envolved.
its a common mod for some of the drag racing guys on here to do.
Old Apr 26, 2005 | 12:58 PM
Steve Rea's Avatar
The shop that did my LS1 conversion for my race-car also fabricated a simple bracket that you can use. If you are interested, you can contact Scott or Mike at www.renegadehybrids.com. They have a P/S delete bracket that should just bolt on.
Tell them Steve says hi.
good luck,
Steve
Old Apr 26, 2005 | 02:19 PM
gnx7's Avatar
What year BMW? Any pics you can share?
What kit did you use and if not did you fab it all?
https://ls1tech.com/forums/conversions-swaps/308379-belt-size-when-no-ps-ac.html
I had to remove the lower alt bolt to clear the belt. THere are still 3 others holding it in place. No worries.
Old Apr 26, 2005 | 03:18 PM
redmist's Avatar
Default bimmer
Thanks for all your help!
I just posted the data on the conversions post so I won't repeat it here.
Needless to say the general reaction from the BMW guys and the Chevy guys is negative. That makes me happy.
https://ls1tech.com/forums/showthread.php?t=308379
Old Apr 28, 2005 | 02:38 PM
55chevy's Avatar
Here's my low tech, red neck solution:
My setup is different but I used a string to measure my belt length. I pulled the tensioner to mid position and wrapped the string around the pulleys. I marked the string where it lapped and then measured the string. I guess I got lucky but the first belt I bought seemed to fit fine.
